Shortcut- \"timeline insertion follows playback\"?
Hi guys,
what is the shortcut for "timeline insertion follows playback"? I tend to inadvertently turn it on when working/typing really fast sometimes. i am in command focus mode in the edit window. can't find it in the shortcut list. thanks! BBB |
Re: Shortcut- \"timeline insertion follows playback
Hi
Not in front of my system at the mo, but I think it is apple key and /. either that or alt and / Regards
Dual 1.8 G5 (1st Gen) 10.3.4 4 GB RAM 2 x Glyph GT050 Pro Tools 6.4 cs9 HD 1 & 96 i/o Waves Gold 867 Powerbook Pro Tools 6.4 & MBox 10.3.4 |
it's the N key.
Re: Shortcut- \"timeline insertion follows playback\"?
It's "Cmd"+"/". If you have command focus mode on, and you hit the "n" key that will toggle the state of the transport from either returning to the timeline insertion after stopping...or moving the timeline insertion to where the playhead was at the time of stopping. It's the difference between working like protools (when you stop, it will start from the same spot) and working like a tape deck (when you stop, it will start from where you stopped).
Cmd+/ will toggle timeline follows insertion. This means that with it disabled, your playhead can start from anywhere regardless of your selection in the edit window and as you change selections your playhead does not follow what you have selected.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
it's "N" - happens all the time.
JW |
maybe I have the names of the two reversed...if Timeline follows playback is N, then what's Cmd+/ called?
Rail
Pouic P. |
Timeline insertion playback issue | boabyd23 | macOS | 2 | 12-21-2010 01:01 PM |
Timeline insertion follow playback bug? | plutone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-27-2009 11:19 AM |
Timeline Insertion Playback turns itself on | HDUser13 | Pro Tools TDM Systems (Mac) | 4 | 08-28-2005 12:00 AM |
"timeline insertion follows playback" | BinkBonk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-26-2005 12:18 PM |
Insertion Follows Timeline Shortcut? | Eric Bazilian | Pro Tools TDM Systems (Mac) | 14 | 06-04-2003 06:30 AM |
