SPDIF connection
I'm using the SPDIF inputs for the first time on my MBOX. The LED is lighting up on the box but the software keeps telling me that the input are not active because of an incorrect path.The paths are active in the I/O setup. I've change the settings in the hardware setup and also in the session setup window. I don't know if I'm missing something. Everything is set to 48hz. Need help
Re: SPDIF connection
Have you set the track that you wish to record on to be SPdif??
Peter |
yes i've done all of that. It stays gray.... I don't know if I'm missing something? I just thought about maybe there is some kind of up grade for the spdif device within the system. I just upgrade my system about 4 months ago.
The original Mbox can only handle 2 channels in each direction, so if you're using the S/PDIF inputs, you need to disable Analog Inputs 1 + 2.
Quad 2.5 G5, 4.5G RAM |
Are you absolutely sure that there is a valid Spdif digital datastream present on the input, ie perhaps try another source. Id not be a bit surprised if a digital input wouldnt enable if the sync werent present.
Peter |
spdif outs connection | Fritz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-25-2012 08:16 PM |
SPDIF connection is great | Leonb | Eleven Rack | 18 | 04-06-2011 07:52 PM |
SPDIF connection | theshizon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-13-2008 04:17 PM |
re-establishing spdif connection after "sleep" | jlcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-29-2007 08:18 PM |
How do you increase levels with spdif connection? | MarkGenero | Pro Tools TDM Systems (Mac) | 9 | 02-29-2004 04:49 PM |
