FW 800 or 400 to connect to Audio Drive
With PT 7.3.1 and my Mbox 2 Pro, it was always said to use the FW400 port on my Mac Book Pro, and daisy chain the audio hard drive and the PT interface from there.
Now, with PT9, and no Mbox 2 Pro (or any other interface) plugged in, is it OK to use the FW800 port to connect my audio drive? Is it still necessary to use 400? Does it matter? Thanks |
Re: FW 800 or 400 to connect to Audio Drive
800 is preferable! 400 is still ok but 800 is much faster will give better performance and higher track count Chris
the problem is mbox 2 pro+fw800
no mbox2 pro - you can use 400 o 800 |
My audio drive only has FW800 ports, and it works like a champ on the FW800 bus (MacBook Pro, early 2008).
MB black + MBox2 Pro: Hard drive connect? | thopman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-11-2009 04:40 PM |
Best way to connect laptop to Digi, external hard drive? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-28-2007 07:31 PM |
How connect FireWire drive? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-28-2006 09:24 PM |
how to connect firewire drive and mbox to ibook | Bluzhorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-29-2003 08:20 AM |
audio in direct connect ? | linpaws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-29-2003 12:36 AM |
