External Mic Pre via Adat to HD IO increase latency or not?
If I get a 16*16 digital Avid HD IO, and I use Ensemble as the mic pre, I connect Ensemble to Avid HD IO 16 digital VIA ADAT, would this kill the advantage of low latency that HD Native/HDX card has?
Thanks! |
Re: External Mic Pre via Adat to HD IO increase latency or not?
No.
Check the specs of the converter in the mic pre. It might say something about "4.2ms latency" or "64 samples conversion speed" but it should indicate it in either time (milliseconds) or samples (which would be exact amount. All AD conversion has latency. It does not matter which company makes the converter card, it will have latency.
That's one of the advantages of the new HD IO interfaces. Because of their newer design, they actually convert faster. So there is an advantage in using them vs. older boxes like what he's using.
Keep in mind that the HD IO is only capable of 16 inputs...period. If you are going to connect an ADAT path, it will negate half of the analog inputs(so the 8x8x8 version would work as well and save you some cash).
How to increase io from 16 to 32 using adat bridge | kevin001 | Digidesign Hardware & Software | 3 | 09-18-2010 04:16 AM |
increase in midi>audio latency?? | 77pro | MIDI | 2 | 09-06-2008 10:14 PM |
External Drive performance increase? 16+MB? 10,000 RPM? | JChance | Pro Tools M-Powered (Mac) | 1 | 11-28-2007 04:54 PM |
Buffer problems - Increase-Decrease-Increase | 6string | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-17-2005 10:01 AM |
001 with 01v via ADAT (latency??) | mwpmorris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-20-2003 06:30 AM |
