Time Comp/Exp ?
Hi ,
I am wanting to use the time compression/expansion plug in to speed up & slow down my audio files. I am wanting to speed up my take say 20% etc, so does any one know the mathematical formula for putting my percentage into the ratio column? Hope that makes sense. Thanks James |
Re: Time Comp/Exp ?
If you make your audio tracks TICK based and enable Polyphonic Elastic Audio, you can simply change the BPM and the audio will stretch or compress(according to the tempo value). A 20% change might have some artifacts, but you can easily turn off the EA and REVERT right back to where you started. If EA gives too many artifacts, then I would get Serato Pitch n Time.
Help still needed with 'identify beat' and 'Time exp/comp' | vitolanzafame | Pro Tools 9 | 2 | 06-20-2012 06:33 AM |
Automated time comp/exp | Benneedshelp | Tips & Tricks | 1 | 06-15-2006 10:03 PM |
audiosuite time comp. exp. ? | lamp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-03-2002 08:07 PM |
Time Comp/Exp Trimmer Weirdness? | barden | Pro Tools TDM Systems (Mac) | 6 | 03-07-2001 06:37 PM |
Time comp/exp over multiple tracks-need help | CCash | Tips & Tricks | 9 | 03-03-2000 03:33 AM |
