Peak indicator
I see there an option to change how peaks are held one the volume indicator, but is there a way to get the peak indicator (the box that you ctrl click to get the readout) to reset back to 0 when the levels drops back to 0?
002, PTLE 5.3.2, A7V266-C, XP2100+ (1.7GHz), XP Home |
Re: Peak indicator
bump
Re: Peak indicator
You may want to rephrase your question. You loose me with "the box that you ctrl click to get the readout".
The Peak indicators are yellow hash marks left on the VU meters showing the hotest level reached by the section played. If you want those to fall to zero, then you don't really want peak indicators enabled. I suspect you are refering to another feature of PT. Sorry, just not sure what you're asking here. |
Re: Peak indicator
Sorry for not being clear. I'm talking about the box above the pan box on the track display. This box reads the plugin delay, the volume, or the peak if you ctl-click it.
The VU meter falls to 0 just fine, but the peak readout (the one that you ctl-click to view) does not. I'm wondering if there is a way to make it reset automatically. It's quite a pain to have to keep clicking it to reset it back to 0.
Re: Peak indicator
Rail
Re: Peak indicator
Oh well.
Thanks for your help Rail.
Shortcut to toggle from Vol. to Peak Indicator line on Channel Strip | larsongs | Pro Tools 10 | 2 | 09-09-2012 07:46 PM |
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 | hotgravy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2012 10:49 AM |
peak indicator and indexing in PT9? | Lou Judson | macOS | 4 | 05-12-2011 12:11 PM |
Mbox Peak / Peak Light Issue | soulcatcher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-29-2004 08:01 PM |
volume/peak/delay indicator problem | Zettt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-14-2004 09:24 AM |
