Old 02-06-2022, 11:23 PM
capt kirk capt kirk is offline
Default Re: Niggling things
i would LITERALLY PAY AVID for implimenting a way to move clips/clip groups up and down vertically locked WITH THE ARROW KEYS.......PLEEEAASE I BEG YOU ..........i cant change from the Audiofile.......Ive tried......Im an old man......please throw me a bone.....
www.kfaudio.ca
Old 02-07-2022, 03:06 AM
midnightrambler midnightrambler is offline
Ooh no you can't change the up and down arrows, they're what we've been using for for start and end locations for decades.
(Which reminds me of another infuriating thing: when you're working have a MIDI or instrument track in the main edit window and the up and down arrows stop acting as they should and move notes instead. So inconsistent)
Old 02-07-2022, 11:35 AM
daeron80 daeron80 is offline
THIS. All the time. Arrows should only move MIDI notes verticaly with a modifier key.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 02-07-2022, 01:32 PM
1m1 1m1 is offline
Batch renaming clips that are full length audio files in the bin (in bold) should also rename the audio file in the Finder (Mac) — or at least make it an option to do so. I NEVER want to rename the clip without renaming the file.
Old 02-07-2022, 01:57 PM
BScout BScout is offline
We've all been begging for this one since batch renaming was introduced.
And, yet, Avid persists to ignore us. (for a change that would take next to no coding -- this isn't one that would take any time at all)
  #16
Old 02-07-2022, 02:31 PM
Sardi Sardi is offline
Hang on, is that actually what happens?
I’ve never used batch rename, but you guys are saying if you rename the parent clip in PT, it does NOT rename the file in Finder? How does that work? It’s just renaming metadata of the file then?
  #17
Old 02-07-2022, 02:56 PM
Batch rename only renames clips whether the clip is actually a "clip" or a full file. And it gives no option to batch rename the full file (like you can with the regular rename.)
The only "work around" is you first "batch rename." And then, while the clips are still selected from the batch rename process, you go into regular "rename" and hit enter for as many clips as you have which advances through the selected clips.
That transfers the new clip name from the batch process to the file (if the clip is a full file.)
It is beyond tedious.
Avid has given some stupid excuses why it isn't an actual batch rename including file names. None of them make logical sense.
  #18
Old 02-07-2022, 03:25 PM
Wow.
  #19
Old 02-08-2022, 11:17 PM
1m1 1m1 is offline
If I only had to rename a handful of clips at a time, okay, no big deal. However in my workflow I'm typically renaming about 80-100 clips at a time, and I only have a 10 seconds or so to do it. So I have to use a non-optimum workaraound which is a drag.
  #20
Old 02-10-2022, 08:23 AM
home_studio home_studio is offline
Default Here's another one:
Dear Avid, when I re-activate a VCA track (after being inactive), please keep active the the tracks' group. It's greyed out and not functioning, only if I re-select the group in the VCA track.
It's quite annoying one would say.
Thanks.
2023.12 Ultimate / Mac Pro (Late 2013) / 6 core 3.5GHz / 64Gb / OSX 12.7.2 / MTRX Studio / 2xArtist Mix / PT|Control / Aja T-Tap
Need to know how to some things... Antboogie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-15-2009 08:03 PM
Need Help with Two Things...... Kazawa Atoll 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-27-2005 08:41 AM
iMac G5 !!!good things and bad things!!! Jervy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-28-2005 01:36 AM
3 things I can't do in OSX Richard Barrie Pro Tools TDM Systems (Mac) 6 06-28-2003 08:42 PM
Will this fix things? jdavis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-23-2001 08:18 PM
