Old 12-09-2010, 04:04 AM
johanonsydow johanonsydow is offline
Default Pro Tools 9 with focusrite liquid saffire 56 problems
Hello.
I own a brand new liquid saffire 56 that I want to use with pro tools 9.
I have it installed on a fresh version of windows 7 proffesional. I only have pro tools and saffire mixcontrol installed, noting else.
I have some very frustrating problems when I work.
Pro Tools keeps giving me these messages:
"ASIO device properties have been changed by the device control panel. Pro Tools must be restarted for these changes to take effect. Please restart Pro Tools.
Save - Quit"
The message can appear right in the startup or during a session of recording
(very embarrassing this weekend when I recorded a band and in the middle of a take this message appeard and stoped the recording, needing to restart.)
Then when I restart this message appears:
"Pro Tools hardware is either not installed or used by another program"
It usually takes 2-5 restarts of Pro Tools before I can continue to work.
What do I do about this?
I'm thinking it can be something with the buffersize. I chose 512 in PT9, but Saffire mixcontroll always sets it at 256.
I change it but it always change it back. Then I try to change PT9 to 256 but it says that I have to do that in the mixcontroll and that I cant do that because the hardware device is being used by another program = shutdown Pro Tools. Back to square one...
Any suggestions what to do?
Old 12-09-2010, 04:12 AM
Meads Meads is offline
Default Re: Pro Tools 9 with focusrite liquid saffire 56 problems
I'm on a mac, so I don't know if my solution refers to PC as well.
I had a hard time getting the setup right, and i figured that the order of launching programs is vital.
Here's what I do:
1. Switch on my machine
2. When booting is completed switch on the Saffire
3. Open MixControl and set it up with values matching your PT-session
4. Leave MixControl running in bg and start PT
Since I do it like that, smootheness all over.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 12-09-2010, 04:17 AM
Great. I'll try that.
I usually do that, exept from switching on the saffire after boot.
Usually do that while starting the computer.
Old 01-13-2011, 03:23 PM
Carpedrum Carpedrum is offline
I'm having some nightmares with getting things to play nice with each other too!
Macbook pro running pt 9---to external drive..(800-800) to saffire 56.(400)
So far I have got the mixcontrol to recognize the saffire only once... and i keep changing the order of the daisy chain to see which one is best suited for my set-up-.- but i'm at a loss for a "proper order of things"... and the saffire 56 has not showed up in the mixcontrol since that one magical moment.
From what I read in the instruction manual ... it looks like I should try the express card so that each firewire is running on a separate bus... (am I understanding that right??)
Why has the saffire stopped being recognized... (I don't think I changed anything)...buuuut maybe I changed a setting within pt 9!?? Isa there a certain setting I should look at?? I'm beginning to loose patients and hair over this....
Old 01-13-2011, 10:27 PM
Default
First thing I need to ask, does the firewire-led light up, or is it dead? If it's on, look into OSX's audio midi setup. Does the Saffire appear in there?
Sent from my HTC HD2 using Tapatalk
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 01-14-2011, 02:35 PM
jarrydee jarrydee is offline
I just got my 56 and set it up with PT 9 very fast..the thing that sucks is that you MUST set the 56 to the correct sample rate before you open a session or you will get the error you been getting....the thing that sucks about that is I have some old sessions that I dont remember the SR I used and I cant open them!!! I just got this hooked up about an hour ago so if I learn more I will post!!!
Old 01-14-2011, 02:57 PM
L-Dogg L-Dogg is offline
I just posted on that but I must say that seems a PITA. Surely there must be some way to set things so it "sees" the SR's of any session?
I just came across some Focusrite stuff on sale but I will now avoid them as it seems there are some problems with PT perhaps?
Mac Studio M2 Max
12-core CPU, 38-core GPU, 16-core Neural Engine
64 GB memory
2TB Solid State Drive
Thunderbolt 4
Sonoma 14.1.2
Pro Tools 2023.9
Universal Audio Apollo 8P (TB3 Option Card installed)
Old 01-14-2011, 03:01 PM
Dism Dism is offline
http://focusrite.com/protools9
I believe this will solve the samplerate issues. It's also why I haven't purchased one of these yet. I wanted to wait until more integrated control is achieved.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 01-15-2011, 12:55 PM
Is this available yet? because I still can not get a session opened or start a new one without all of the problems the OP has listed...this is crazy !
Old 01-16-2011, 09:33 AM
GAS GAS is offline
I went through the exact same problem and it drove me crazy for a few days.
My issue turned out to be a conflict with my D-Link PCIe wireless network card. I have to disable it before launching PT and it's fine.
I really hope Focusrite or PT has an update at some point to resolve this.
As mentioned, do launch MixControl first.
I currently often have to start PT twice, but once it's running it's been stable. It just takes forever to actually get going. The first time takes about 5 minutes to load PT, then the restart goes much faster.
Good luck.
[IMG] code is Off
Pro Tools 11 and Focusrite Liquid Saffire 56 Erik318 Pro Tools 11 4 07-03-2013 06:55 AM
Focusrite liquid saffire 56 and PT 9 BIG PROBLEMS! jarrydee Windows 17 12-27-2011 02:01 PM
Focusrite Liquid Saffire 56 and PT 9 ? trock Pro Tools 9 5 09-19-2011 04:27 PM
PT9 with Focusrite Liquid Saffire 56 problems RustRecording macOS 4 07-27-2011 03:38 AM
I/O from Focusrite Liquid Saffire 56 in PT9 PUMASALAD macOS 7 04-14-2011 11:31 AM
