#1641
Re: Best System for PTLE for under $1000.00
Allen,
Thanks, found the header in a box of stuff I didn't think I neded. Got the drive installed and had trouble becasue I needed FAT32 and the only option it gave me was NTFS. Finnaly figured out to reduce the partition size to 32G and FAT32 miraculously popped up in the options. Can't imagine being able to get all this done without the help here on the DUC and from you especially Allan. Mny, many thanks and good karma will obviously follow you all the days of your life. rick |
#1642
I too want to thank Allen and everyone else who helped me with my Allen PC. I finally got my A7V333-XL & AMD 2800+ to co-exist (see Gene's post in the 'AMD Barton' thread). Now I'm enjoying 2.083GHz cpu speed! Many thanks Allen and all!
#1643
Thought I'd better post that fix here too:
go to PCI configuration then go to PRIMARY VGA BIOS [PCI VGA BIOS CARD] make sure it says [AGP VGA CARD]. Congrats on getting your system up and running full speed. Allen [img]images/icons/wink.gif[/img] |
#1644
Just swapped out the WD 80GB drives for the new Hitachi/IBM 120GB 8MB cache 180GXP series drives. Quieter and faster than the WD drives and come with 3 year manufacturer warranty despite the misprint at www.newegg.com of one year.
#1645
I also see you've got the XP 3000 up there now... is anyone actually using one yet? Anyone with a Digi 002? Any DaveC test results yet with that CPU?
I'll probably just wait for a clawhammer, but if it's faster than my 2700... [img]images/icons/wink.gif[/img] [img]images/icons/grin.gif[/img]
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
#1646
Hi Phil.
Best regards, Haigbabe
Drive fast, take chances |
#1647
Best regards, Haigbabe <hr /></blockquote><font size="2" face="Verdana, Arial">I assume we're talking about the 3000 barton. Slower than the 2800 Barton? Or the 2800 T-bred?
Digi 002 Dual 2.0 G5 |
#1648
Regards, Haigbabe
#1649
Hey everyone,
I'm building an PC to run PTLE / 001. I've purchased everything on the main page of this thread (Just waiting for my volcoano 9 to arrive to begin assembly). I have a few quick questions: 1.) I ordered the most recent power supply listed (EG365P-VE), and because of the extra fan on top of the power supply, it doesn't look like it will easily be installed into the recommended case without some physical alterations to either the case or the power supply. Anyone else run into this? Am I missing an obvious solution? 2.) I'm noticing that pretty much every step by step walkthrough recommended here focuses a lot of time on promise cards, which aren't mentioned in the first post of the thread. Is this required? If not how much better is the performance with a promise card? 3.) What's te best source for this arctic paste everyone talks about? Hardware store? A certain website? Thanks a lot in advance for any help you can give me. cheers, ak |
#1650
i just purchased and installed a ADS Pyro 1394 Drive Kit. i equipped it with a 120GB hitachi/ibm hard drive (the one recommended by on this string). unfortunately when i try to format the drive it gets to 89% complete and then stops. i get an error message that the drive has not been formatted correctly. any suggestions?
Pro Tools-qualified desktops outdated??? | robotboy | Windows | 4 | 05-28-2013 05:02 PM |
HP Desktops? | whatwhat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-29-2009 09:33 AM |
HP Desktops in LE?? | finman29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-06-2008 11:06 AM |
Pro-Tools and RAM Drives. Laptops/Desktops - Possible? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 09:34 PM |
HP Desktops | my cardboard box | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-05-2004 07:27 PM |
