DOS on a MAC
Steve-I realize this is not PT related, but I thought you might offer a suggestion:
I bought an IBM 9 gig internal drive to put in my Akai S5000 sampler. It is unformatted. The S5000 wants the drive to be DOS formatted. I'm up to my ears in Macs without a single DOS machine in sight. Is it possible to DOS format with a mac (it's a scsi drive)? I've checked Drive Setup 1.8.1 and HDT 3.0.2 with no luck. Thanks for your help. ------------------ http://www.ripplefx.com
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 |
Re: DOS on a MAC
Thanks for your reply Steve. I'll look up DataViz and see what they offer. Another user suggested Formatter5 from Software Archetects, so there two possibilities. Anyway I'll post a solution if I find one.
Thanks again. ------------------ http://www.ripplefx.com
Re: DOS on a MAC
Rip,
I don't know of any formatting utility that will create DOS volumes from a Mac. We use a utility called MacOpener by a company called DataViz. It allows us to mount and create HFS volumes on Windows. It's possible they may have a utility that works the opposite way. Try looking them up on the web. Hope that helps. --Steve Rosenthal, Digidesign ETS
--Steve Rosenthal, Digidesign ETS |
Re: DOS on a MAC
your sampler should be able to format your drive. i have no experience with the akai 5000 but i know the mpc-2000 will format hard drives. my emu does too.
Re: DOS on a MAC
My problem was that the brand new unformatted drive caused the S5000 to not boot. It would hang upon startup. The solution for me was to use 'MultiFormatter' which is a part of 'DOS Mounter' from Software Architects. The S5000 only recognizes the first 6.4 GB in three partitions, but it's better than nothing!
Re: DOS on a MAC
Formatter Five works just peachy for me and my K2000.
E.D.
Neotech Concepts http://www.imdb.com/name/nm0235036/ ! sonic gymnastics for the illusionary arts ! 2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch, EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB |
