Old 12-12-2002, 03:17 AM
Craig Golding Craig Golding is offline
Default From OS 9 to 9.2 does it really matter?
Sounds like a bit of a dum question but should I really consider updating the OS for my home rig? Everything has been fine running PTLE 5.1/001 on OS9 so does 9.2 really matter or is it more effort than its worth? [img]images/icons/confused.gif[/img] I feel like I should always try and keep things up-to-date as poss. What you you guys reckon?
C.
C.M.G SOUND
Old 12-12-2002, 07:12 AM
where02190 where02190 is offline
Default Re: From OS 9 to 9.2 does it really matter?
IMHO, yes you should update. 9.2.2 is extremely stable and yields a slight increase in performance. We've been running it for several months and are very pleased with the results.
Also, 9.2.2 is the end of the line of r OS9, there will be no further upgrades from there. It will be the last upgrade you'll need to do.
Hope this is helpful.
Old 12-12-2002, 08:35 AM
tommydee tommydee is offline
where0129 really knows his stuff, so trust him more than me...
however, if i ain't broke, don't fix it -- all the probs i have is when i tinker for the sake of tinkering, and then spend hours fixing.
t.
Old 12-12-2002, 08:53 AM
DOUBLE EDGE DOUBLE EDGE is offline
i had problem with 9.2.2.. it caused alot of errors while loading up extensions. so i satyed at 9.1 which has been great...so far
Mac Pro 2.66 - PT 7.3.1 cs2 -
Old 12-12-2002, 09:41 AM
William.E.Lemuel William.E.Lemuel is offline
The cool thing about the upgrade, is that you can download it for free at the Mac website. The answer to your question is "Six in one hand, half a dozen in the other." I was running Os 9, but I was forced to upgrade by my new Stylus Vinyl Groove Module, because it won't operate on anything less; and I imagine that this will happen over and over again as far as the newer third party development goes. So yes definitely upgrade, because as I just said if you plan on using newer software like Stylus, you'll need it.
WLTruesongs
Old 12-12-2002, 10:58 AM
KennyB KennyB is offline
I had problems with 9.2 when trying to run applications that had been installed under 9.0.4 - errors of types 1,2,3,10, and eventually it wouldn't boot at all.............
Applications that were installed under 9.2 were fine though (initially).
Back to 9.1 and all is better !?!
Old 12-12-2002, 11:20 AM
The Mighty Burner The Mighty Burner is offline
Craig -
I recently wiped my system drive to start from scratch, and the first thing I did after reinstalling OS 9.0.4 was upgrade it. Be advised though that you cannot upgrade directly to 9.2.2 from 9.0.4. You must first upgrade to 9.1, then 9.2.1, then 9.2.2.
I have to say that I am enjoyed improved performance across the board (stability, speed, power, etc.), and I do recommend you try it.
If wiping your system drive is an option for you (it's alot of work to back up everything, and it's just nervewracking to boot....well, at least the first time you do it), and your nervous about it, I would suggest you protect yourself as I did. When I initialized my system drive (it's 30Gb), I partitioned it into three 10Gb partitions (after you partition your drive, you can initialize the partitions individually). I then installed OS 9.0.4 on two partitions (the third is to back up my external firewire drive). I only upgraded one of them, so in case I had a problem I could always use the second partition as a 9.0.4 startup disk. Once I got to 9.2.2, reinstalled all my third party stuff (like PTLE) and was comfortable with it all, I reinitialized the second OS9 partition and installed OSX (in preparation for PTLE 6.0....I have a dual proccessor!). OSx is good to have too....It's nice and a lot more fun than OS9. I find that for PT I startup on the OS9 disk, and for other general email and internet stuff I boot up on OSx. So far, it's been superb.
BTW...Where is good people...he helped me out a couple of times, and I trust his advice.
Hope this is helpful,
The Burner
Old 12-12-2002, 11:32 AM
Ok Ok enuf butterin' up!!!!!!
thank you for your kind words....
Old 12-13-2002, 03:41 AM
Slovenec Slovenec is offline
Im running Protools LE 5.1 on OS 9.1 and everythig is working just fine. Today was the 1st time that my Mac ran out of juice (working on an albumr for a client) and yeah 'audiosuite' rules in that scenario LOL:).
Ive decided to stick with 9.1 only because it's behaving itself and I don't want to screw up anything just for the sake of an upgrade.
When Protools 6.0 is out on OSX then I will take the plunge in that direction but ONLY after ive sat back and taken note of how well it is behaving. Until then, OS 9.1 is the go for me!
Old 12-13-2002, 04:11 AM
The thing I love about DUC is that you guys actually take the time to reply. Even on a relatively unexciting topic such as this one!
Thanks for the advice, I think I'll go for it and see what happens! [img]images/icons/shocked.gif[/img]
Do I to have intialize the system drive to upgrade the OS or can I do it without this process?? Suppose I could always copy stuff to my other drive?
Thanks for all the advice. [img]images/icons/smile.gif[/img]
C.
C.M.G SOUND
No matter what im screwed it seems! AudioKillaSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 09-20-2009 10:17 PM
the box doesn't matter? mcconnellsteve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-25-2006 06:01 PM
Re: Cannot Relink no matter what!! mikef585 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-15-2005 08:23 PM
DOES IT MATTER? jon one 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2003 08:26 PM
Rambus or DDR ? Does it matter ? Maceo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-23-2002 02:34 PM
