Old 05-12-2021, 08:47 AM
stargazer stargazer is offline
Default Durability of HDX cards
My HD Omni died, so I’m getting a replacement.
I’ve had it for around ten years, like my HDX card.
I’m thinking of getting a used HD Native PCIe card as a temporary backup in case of failure.
(Avid End of Life Dates):
https://avid.secure.force.com/pkb/ar...-support-dates
Are you trusting your HDX cards to be reliable for some more years?
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 05-12-2021, 02:59 PM
XJENSEN XJENSEN is offline
Default Re: Durability of HDX cards
Don't do it. HD Native is no replacement for HDX. It only kind of half works.
Old 05-13-2021, 02:15 AM
Can you explain more?
I’m thinking I could use a Native card if my (I only have one) HDX card breaks, as a temporary solution while waiting for a new HDX card.
With a Native PCIe card my HD Omni would still be usable, I hope?
I can get a used Omni with a Native card for roughly the same price as a replacement Omni from Avid.
Buying from a private seller I’d only loose the 3 months warranty that Avid offers with their refurbished ones.
Also, at the moment I have no HD compatible interface at all, so I use an old Fast Track Solo, to be able to work at all.
Obviously, I can’t use DSP plugins or my HDX card, but I can edit and mix if the sessions aren’t to demanding.
So a HD Native and an Omni would be a step up as a backup/emergency setup, compared to the Fast Track, I guess (if it works)?
Old 05-13-2021, 02:58 AM
LDS LDS is offline
It depends what you are doing, really. My HDX card is sitting on my shelf at the moment. I'm using a HD Native PCIe card as it hosts a much bigger session due to the 384 voices it has.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 05-13-2021, 03:20 AM
Ok, thanks!
I wonder what XJENSEN means by ”it only kind of half works”.
Maybe he’s just referring to the latency aspects while recording and the lack of DSP on the cards?
Old 05-13-2021, 03:24 AM
Then it would make sense to get a HD Native PCIe card if I get a very good price as apart of a package deal with an HD Omni.
Old 05-13-2021, 03:25 AM
My initial question was regarding the durability of the HDX cards. Do I need to worry about that at all?
My rig is around ten years old, and my Omni just died, hence my concern.
Old 05-13-2021, 04:59 AM
LDS LDS is offline
I don't think there is anything inherently unreliable about HDX cards... but with that said, nothing lasts forever either. If you are anything like me, the worry is purely a symptom of not having an adequate plan B in place.
Old 05-13-2021, 05:32 AM
Thank you, LDS!
Old 05-13-2021, 08:44 AM
Ok, thanks!
Yes, I was indeed referring to the known latency and LLM problems with HD Native. Plus lack of sidechain compensation and a few other things.
As for durability of the HDX cards, every firmware update is a serious risk, as it is known to fry some DSPs occasionally. You can bypass broken DSPs if you want, so it doesn't make the card completely unusable if it happens. I also believe the ball grid array soldering of the chips is prone to mechanical damage.
Just a few thoughts.
Mac 12 Core + 2 Hdx Cards + Magma Digi Rev B + 3 Uad Octo Cards + Pro Tools 12.8.3 drago76 Pro Tools 12 2 12-19-2019 09:38 PM
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 02:39 PM
002 Durability with touring Andrew814 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-05-2009 07:05 PM
Durability of Digi 002R btdvox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-22-2005 11:20 AM
Problems already! Worried about Digi001 durability. tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 46 05-20-2001 12:58 AM
