Old 09-27-2009, 12:30 PM
AndyJCP AndyJCP is offline
Default What difference will an outboard pre make?
Sorry, may be difficult to answer.
But I'm thinking about adding a decent pre-amp to my setup. Something like a Mindprint Envoice, SPL Goldmike or similar price range.
I want to use it mainly for recording vocals.
My main vocal mic is a Neumann KMS105. But I also use a simple SM58 for some vocals.
Currently, I feed the mic directly into my Digi003 pre-amps.
I like the sound, but I heard that a good pre can make a huge difference in several other threads.
What would you experts say? In the chain mentioned above, would a pre <1000$ really make a huge difference?
Thanks,
Andy
Old 09-27-2009, 01:15 PM
RiF RiF is offline
Default Re: What difference will an outboard pre make?
It depends on so many aspects if YOU will hear a significant difference.
I would recommend to order those preamps and A/B-compare recordings through these pres with those you do using your 003's pres. If you hear $1000 worth a difference, keep them, if you don't, return them.
Old 09-27-2009, 01:37 PM
sw rec sw rec is offline
FWIW I NEVER use on-board preamps. Not in the 002R, not on my console. The Joe Meek VC1Q that I use with my AKG Solidtube sounds GREAT, and it was $600. Also using a (discontinued...) DBX 586 on my Groove Tube MD1 mics,(backed up by a Meek SC2.2 and a BBE 882i) and they sound killer as well. That pre was $750 for two channels. Cool thing is, you see stuff like this on Ebay all the time for pennies on the dollar.
Just my 2 cents worth.
Old 09-27-2009, 02:42 PM
Murt Murt is offline
Yes it can, along with a good song, good talent, good tracking, a good engineer, good equipment, good musicians and a good recording and listening environment.
I know....sorry to be facetious, but it's only one link in the chain, literally.
MBox2Pro / LE 8.0.5
Old 09-27-2009, 04:01 PM
GothicV GothicV is offline
All the difference in the world.
I own a Mindprint EWnvoice and it's great for the money, and the comp and eq sound really nice and smooth.
Old 09-27-2009, 05:13 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
If u have the money, get a pre..Just don't get addicted @ buying(like I & others did/do)
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 09-27-2009, 06:20 PM
The Weed's Avatar
The Weed The Weed is offline
G.A.S. is a dangerous obsession!
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-28-2009, 02:33 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Cheers,
+1.
It should be a official diagnosis
Old 09-28-2009, 10:25 AM
Well, yes, but it's one link in the chain that's easier to upgrade than talent, a good song etc.
Old 09-28-2009, 01:01 PM
Benoni's Avatar
Benoni Benoni is offline
Cheers,
I believe i have a terminal case
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Should I buy new Mac Pro -will it make any difference ? hwill2008 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 47 09-09-2010 03:23 PM
Big Ben - How much difference will it make? Colbyjack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 06-22-2009 12:51 PM
SP1---does it make a difference? nightshadecrisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-02-2004 12:52 PM
is more RAM going to make a big difference? starlightmints 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 02-10-2004 01:49 PM
Does it make a difference??? GZUZIZLORD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-14-2003 11:29 PM
