Mix sounds muffled
Having problems mix a song. Its very low tone, which is think is why it sounds muffled. I added a L1 limiter to master track which makes it sound more filling. Then started messing with EQ, but ended up deleting that.
Friend told me to try an exciter, but i don't know where to find one. I also did a C4 compressor and use the setting, uncompressor, which helped it out. Any ideas?
www.codehero.net |
Re: Mix sounds muffled
wow.. what kind of mixer are you using to send it to the Digi? I use a Allen And Heath and my mixes are very lively.. Also it depends on the rooms you record in.. So many things can cause this problem! Dont buy gear though! Find out how you can maximize your stuff first!
I use just the Digi001 gear. I figure i spent $800 on it, i'm using every bit of it before i buy more crap. I record guitar amps in a closet full of clothes. I think its because the mic placement of the condensor mic being to high, and the shure 57 being very close. Going to do some over-dubs with the guitar going straight to the digi, maybe get a better tone. Also re try the EQ and lower bass and raise treble.
Yea i'll can post it, it will later tonight.
www.codehero.net |
I get a very satisfactory guitarsound by close-micing the cabinet with an sm-57. Just make sure you crank up the amp, so it has a nice sound. The sm57 can take that beating....
What's that? - That's the machine that goes "pling". Bastiaan |
Muffled Audio | apollo19 | Tips & Tricks | 5 | 11-22-2013 06:16 AM |
muffled playback? | TheLibrarayTim | Pro Tools 11 | 3 | 07-25-2013 08:08 PM |
Muffled playback | pumpkinheady | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-14-2006 06:11 PM |
Recording quality not so good...sounds muffled | rkohli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 28 | 05-04-2005 05:16 PM |
Finalized CD recorded from MBOX sounds muffled | Emagin7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-18-2003 11:36 AM |
