Audio Clipping/Output Problems
Hello everyone,
I recently upgraded my DAW to Pro Tools after using Garageband to record for a few years. My MacBook crapped out, so I thought I would try the Pro Tools subscription on a new PC (HP Envy, Intel Core i7 - 16 GB RAM) as an upgrade. Right now, I mostly just record drum play-alongs to existing tracks. I imported the audio track into Pro Tools 12, and had the audio run through my interface (an audiobox 1818vsl). Even with the headphone volume maxed out on the interface, the track is barely above a whisper. When I turn up the db of the track within Pro Tools, it quickly begins clipping out and distorting badly, and still isn't loud enough to track a full drum kit to. The strange thing to me is that the volume is fine ( and doesn't clip) if the interface isn't set up in my playback settings, and I'm just listening directly from the computer's output. In GarageBand, you could just set the interface as the audio input, and the computer as the output, allowing me to plug headphones straight into my computer to easily monitor my own drum tracks and play along to whatever song I was recording. Pro Tools is a lot more complicated than that, and I haven't been able to easily figure it out, or find any videos/threads on the matter. I have the feeling this is probably an easy fix, but I'm at my wits end. Any help would be GREATLY appreciated! |
Re: Audio Clipping/Output Problems
COMPLETE system specs, please:
http://duc.avid.com/showthread.php?t=300050 First guess, though....which drive are you recording to? |
Sorry about that, complete details and Sandra report below. I'm not sure on the drive....Setup>Disk Allocation shows my c: drive, do I find that out somewhere else? Thank you for your patience! This is really my first hobby that relies heavily on computers, so still learning a lot.
Computer - HP Envy w/ Intel Core i7-6700 CPU @3.40GHz RAM:16GB System Type: 64 bit Operating System, x64 based processor OS: Windows 10 Home DAW: Pro Tools 12 Presonus Audiobox 1818 vsl, via 2.0 USB Sandra Report: ID Host Name : DESKTOP-NOLOSIN Workgroup : WORKGROUP Computer Model : HP 750-124 103C_53316J G=D Serial Number : MXX62***** Chassis : HP Desktop Mainboard : HP 2B47 BIOS : AMI (OEM) A0.16 03/17/2016 Intel vPro : 11.00.01.1001 Total Memory : 15.9GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (4C 8T 3.91GHz, 3.9GHz IMC, 4x 256kB L2, 8MB L3) Chipset Memory Controller : HP Core (Skylake-D QC) Host Bridge/DRAM Registers 100MHz, 2x 8GB DIMM DDR3 1.87GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Micron 16KTF1G64AZ-1G9P1 8GB DIMM DDR3 PC3-14900U DDR3-1868 (13-13-13-34 5-47-15-7) Memory Module : Micron 16KTF1G64AZ-1G9P1 8GB DIMM DDR3 PC3-14900U DDR3-1868 (13-13-13-34 5-47-15-7) Video System Monitor/Panel : Hewlett Packard HP 27es (1920x1080, 27.2") Video Adapter : Intel(R) HD Graphics 530 (24CU 192SP SM5.2 1.15GHz, 768kB L2, 128MB DDR3 1.87GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : Intel(R) HD Graphics 530 (192SP 24C 1.15GHz, 512kB L2, 6.4GB DDR3 1.87GHz 128-bit, Integrated Graphics) Compute Shader Processor : Intel(R) HD Graphics 530 (192SP 24C 1.15GHz, 768kB L2, 128MB DDR3 1.87GHz 128-bit, Integrated Graphics) OpenGL Processor : Intel(R) HD Graphics 530 (192SP 24C 1.15GHz, 768kB L2, 128MB DDR3 1.87GHz 128-bit, Integrated Graphics) Storage Devices Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) : 2TB (C:) (D:) hp HLDS DVDRW GUD0N (139.8MB, SATA150, DVD+-RW, CD-RW) : 133MB (E:) Logical Storage Devices Windows (C:) : 2TB (NTFS, 4kB) @ Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) Recovery Image (D:) : 12GB (NTFS, 4kB) @ Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) Windows RE tools : 980MB (NTFS, 4kB) @ Seagate ST2000DM001-1ER164 (2TB, SATA600, 3.5", 7200rpm) AudioBox Family_ (E:) : 133MB (CDFS, 2kB, Read-Only) @ hp HLDS DVDRW GUD0N (139.8MB, SATA150, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : HP Sunrise Point-H LPC Controller LPC Legacy Controller 1 : T2 86-13 Audio Device : HP Sunrise Point-H HD Audio Audio Codec : Realtek Semi 0867 Audio Codec : 32768 0000 Disk Controller : HP Sunrise Point-H SATA controller [AHCI mode] Disk Controller : HP Sunrise Point-H PMC USB Controller 1 : HP Sunrise Point-H USB 3.0 xHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : EPSON XP-620 Series (360x360, Colour) Printer : Send to Microsoft OneNote 16 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : Microsoft Print To PDF (600x600, Colour) Printer : HP ePrint (600x600, Parallel, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : EPSON XP-620 Series (360x360, Colour) Network Services Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : Intel(R) Dual Band Wireless-AC 3165 (802.11n (HT), AES-CCMP, 72.2Mbps) Operating System Windows System : Microsoft Windows 10 Personal 10.00.10586 Platform Compliance : x64 |
Looks like you only have one hard drive...for this to work right, you should be recording to a qualified secondary, dedicated hard drive. 7200 rpm, and for the latest incarnations of Windows, use USB 2 or 3 if you're going to use an external. Stay away from green and blue drives, and don't even think about a 5400 rpm drive. I'd highly recommend a Western Digital BLACK drive (with no power-saving protocol.) Just make sure it's 7200 rpm. The forum is full of reports like yours, trying to force the system drive to do too much. From the original system recommendations:
"IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive." Other thing that comes to mind, make sure Windows is not using your interface (what kind of interface?) as the default sound device, and make sure your sync source is set to "internal." |
Edit window visual clipping and audio clipping question... | Jakay | Pro Tools 11 | 4 | 07-22-2015 06:52 PM |
m audio fasttrack pro output pot problems | jbreeze | FireWire & USB Audio Interfaces (Win) | 4 | 02-11-2015 02:31 AM |
Clipping Output... What? Help! HD Pro Control | DrewHardwick | Pro Tools TDM Systems (Mac) | 7 | 09-27-2005 11:52 AM |
Audio output problems again!!!!! | chagos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-18-2004 02:54 PM |
Maxim output clipping | burningbusch | Pro Tools TDM Systems (Mac) | 5 | 07-26-2003 12:29 AM |
