Muffled Audio
Hey whats going on people?
New to this forum, and pro tools audio engineering in general so BE FOREWARNED, do not continue reading this post unless you have zen like patience With that being said, I recently bought a maschine mk2, hooked it up to my stanton t.92, chopped up a sample, and was pleased with the result. not too familiar with mixing and mastering, and although I understand that is of the utmost importance, even though it is not at studio quality I think I did a fairly good job getting my beat to decent levels.... to a point where it could be listened to without people running the opposite way cringing. Now when I import the .wav files from maschine into protools 8 le, I messed around with the EQ and compression a bit. Like I said when I played it back, it sounds decently good (IN PROTOOLS), HOWEVER, when I bounce it to disk and play it back, say in itunes (without converting to mp3), it sounds FAR WORSE and completely muffled and all muddied and messed up. ABRIDGED VERSION, in PROTOOLS it sounds fine in playback, its only when I bounce it (bit rate 24, sample rate 44.1 hz) to DISK and play it back it sounds MUCH WORSE. Any idea why this could be happening? appreciate the read and thanks in advance for your time/expertise/and much needed HELP! lol -19 |
Re: Muffled Audio
what is iTunes playing out of? your Pro Tools interface or the computer speakers?
Is the original track mono or stereo? is the bounce mono or stereo? also please review the Help Us Help You guide lines, not that your problem directly relates to it but you did leave out a lot of details that are good state when asking for help
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig Last edited by Craig F; 11-21-2013 at 09:38 PM. Reason: sp |
Re: Muffled Audio
I will definitely read those guidelines, trying my best not to be a nuisance on this site and learn as much as possible! The track was imported as mono and I bounced it as mono as well. My computer is hooked up to my mbox mini so both the pro tools and itunes playback is through my M audio bx8 monitors. |
Re: Muffled Audio
Is the iTunes EQ disabled?
And in the iTunes preferences, the choices having to do with "quality" and auto volume, under "playback", should be unchecked. Anyway there will be a difference in playback level that you must adjust manually. |
Re: Muffled Audio
I'm assuming that it has something to do with the settings that I am using to bounce the track. Not sure though, thanks for your help |
Re: Muffled Audio
Uninstalling and reinstalling what?
muffled playback? | TheLibrarayTim | Pro Tools 11 | 3 | 07-25-2013 08:08 PM |
Muffled playback | pumpkinheady | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-14-2006 06:11 PM |
EQ on PROTOOLS i sound muffled | Prawjikt | Tips & Tricks | 5 | 12-06-2004 08:23 AM |
Mp3 Bounce Option muffled???? | thissucks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-31-2004 06:48 PM |
Mix sounds muffled | toadiesXJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-22-2002 02:52 AM |
