#101
Re: MDW Massenburg EQ for AAX
Features • High-resolution 96 kHz sample-rate pro- cessing for audio recorded at 48 and 96 kHz, and 192 kHz sample-rate processing for 192 kHz audio. • Wide frequency selection from 10 Hz to 41 kHz on every band • Separate three- and five-band plug-in ver- sions • DSP efficiency (Pro Tools HD only) • A/B compare feature • Phase Invert switch • IsoPeak®—A simple and fast tool to isolate that frequency you’re looking for • Available in TDM/RTAS/AS or just RTAS/AS configurations
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
#102
Just curious why this is... Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#103
The 5x performance number we advertise for HDX is an average of various plug-ins comparing board-to-board, not chip-to-chip. So, on average, you would see an increase of 2.5x chip-to-chip. Some plug-ins are 1 to 1 on the chips. Some are 11 to 1. Depends on the specifics of the algorithm and how well suited it is to to the new DSPs. To the best of my knowledge we don't have any that perform worse. And most perform way better. Another thing to keep in mind is that some plug-in companies take the increase in performance of these chips as an opportunity to increase precision or add features to the algorithm. We've done this with some of our plug-ins, and I'd expect the same for some plug-in companies. Dave |
#104
In the end we'll see not that dramatic increment in processing power (instances per chip) but more quality in processing itself, be it EQ, Dynamics or Reverb. Still worth the upgrade.
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
#105
Any more word on the upgrade problems?
Shane Olivo Bobby Peru Recording The New Loud Milwaukee, WI Check out my studio :) http://www.bobbyperurecording.com Check out my band :) http://www.newloud.com |
#106
I would like to know this, too as the upgrade is back online.
Oliver |
#107
I just did the upgrade via the avid store. Worked fine but I went from MDWv3.0 TDM/RTAS to v5.
Had to surrender the v3 license. Frank.
#108
The Avid Store page for MDW EQ v5 has not been updated or changed, because on the last line is still written 'Supports both TDM and RTAS plug-formats'. This error was confirmed by Avid, but nothing has changed since 7 days. How hard can it be to delete one line of text on a webpage?
So actually Avid is still misleading potential customers with 100% false compatibility information about MDW EQ v5...
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
#109
Or is there something I haven't seen yet? frank.
#110
I just want to update everyone that now the update process works...
When I clicked again on "download" on the email receipt of the purchase now it recognize the mdw 3.0 license present in my ilok and let you go through the download and installation process. Thanks Avid for fixing this.
Massenburg MDW Hi Res 3.0 | Samscasa | macOS | 0 | 05-30-2012 04:27 PM |
10.1.3 took Massenburg EQ | Sam C | macOS | 3 | 04-30-2012 04:53 AM |
massenburg eq bug | dawkab | Pro Tools TDM Systems (Win) | 2 | 02-11-2006 12:14 AM |
Massenburg EQ vs Sony with massenburg mod | Rectifried | Pro Tools TDM Systems (Mac) | 3 | 06-09-2003 12:15 AM |
Massenburg PT EQ ? | haze | Pro Tools TDM Systems (Mac) | 0 | 05-10-2002 12:08 AM |
