What sample rate is everyone using?
Curious as to what professionals are using for recording audio. In my prior life I was using digital multi-track tape at 44.1 khz. My interface allows me to choose 44.1, 48, 88.2, and 96 khz. I assume I should be using 88.2, staying with a mutiple of the CD format, but not sure what the best option is.
I also notice that everything on the internet seems to be at 44.1 - why is that? Is it just about conserving bandwith on the downloads?
Steve Holt The Inner Music & Media Group Voice Actor Steve Holt! Holt Remembers - Meetings With The Remarkable Windows 7x64 SP1, AMD Quad Core A8-3870 APU 3GHz, 8GB RAM, Graphics AMD Radeon HD 6550D Pro Tools 10.3.2, RME Fireface UC, MOTU 24 I/O, BLA Micro Clock Mk2, Soundcraft Ghost, DA-88 (3) Digital 24 Track TC
Outboard: Neve, API , Manley, Phoenix Audio, Teletronix, Drawmer, Universal Audio, Alan Smart , DBX, T.C. Electronics |
Re: What sample rate is everyone using?
44.1 is the standard for CD's and music.
48 is the standard for film/video. The higher sample rates are multiples of these two standards. While your ear technically shouldn't be able to hear the difference between the two, the argument for recording at higher sample rates is that you have 2x or 4x more audio, which is less likely to accumulate artifacts as you add mixing and processing. I generally work at 48 since I'm usually scoring music to video, and most using sample libraries. If I record a live musician, and it's something worth keeping a higher resolution archive I might want to revisit later on, I will usually record it at 96k or 192k just because I can, it's nice to have a higher resolution original recording in case I ever come back to the project in a few years. But most of the time 48k it where I work.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
i do high end post , where we deliver 48khz , which is fine. i also do high end acoustic music, where we record 192khz, and then downsample depending on the deliverable. quite frankly 96khz is perfectly fine as well. we record at 192 because we can but some sytems really choke when doing punches etc....
www.kfaudio.ca |
I work in 48. CD is dying format. Don't really see the need to continue support for it. They are good for handing out at shows and stuff, but I think it's time to move on to something better. iPods and iPhones can play 24bit/48kHz, and probably even higher. Media storage pricing is going down and the capacities are going up. This is why I offer my album in 24bit/48kHZ, which is what I record in, in addition to CD format and MP3. But I think it's time for engineers or someone to increase CD quality.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
I usually use 44.1 for music.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
44.1-48k is good enough for music consumption by the general public,
96k is preferred for mastering anything higher is a personal choice but not necessary to get a better result. |
So no one is using 88.2?
Make records that kick ass at 44.1, then try moving up. Unless your work is KILLING already, you're wasting your time IMO.
I always use 96 k.
Windows 7 ultimate 64 sp1. intel i5 2500k 3.30 ghz. asus p8p67 evo rev 3. 16g kingston ddr3 1600. Asus engtx 560dc2 oc. Seagate Barracuda 7200 9 SATA 80-GB Hard Drive. 2x WD caviar black 7200 500 GB. 1x WD caviar black 7200 1 TB. Seagate Freeagent 7200 1 TB usb 2.0. SIIG NN-440012-S8. PT 10. SIB 7. ProjectMix I/O. Focusrite Liquid Saffire 56. Focusrite Saffire pro 40. Genelec 8040. Axiom pro 61. Alesis Dm8 pro. Spector ns2000/5. Old vintage Vantage electric guitar. Bunch of VI's and plugins
some situations 48k is perfectly fine.....but on very expert acoustic music, you will hear and appreciate the difference 96k makes. 88.2 seems to be getting left behind, like 44.1, for the stated reasons...48/96 is the way to go. 192 is overkill, but we use it for the high end music stuff....
www.kfaudio.ca |
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up | finalcut | Windows | 12 | 02-20-2012 04:00 AM |
Bit Rate / Sample rate | supersam83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-25-2010 08:55 PM |
MBox Micro Sample Max Sample Rate Only 48 kHz? | Joe Sciacca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-07-2008 12:52 PM |
Bit Rate/Sample Rate problem? The chipmunks? | bspro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 05:40 PM |
Bit rate & Sample Rate | WizDoomBorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-02-2002 12:54 AM |
