Old 08-03-2022, 11:24 PM
simonchase simonchase is offline
Default MacOS can't eject a drive with Pro Tools running
When I try to eject a drive I get the error message:
The disk "Simon's Disk" couldn't be ejected because "Pro Tools" is using it.
Quit that application and try to eject the disk again.
But I have no session open. I'm sure Pro Tools fixed that some versions back. But it seems to have been back for a while. For me at least. Anyone else?
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 08-04-2022, 01:01 AM
Default Re: MacOS can't eject a drive with Pro Tools running
Pro Tools version? macOS version? Filesystem type? Signature correct?... if so I'm close with running 2022.7 and other recent releases on 11.6 and 12.x on a similar era Intel MBP and have ~dozen APFS and exFat filesystems mounted and never have noticed this.
What is on this drive? Your home directory? (Yes you can't be unmounting your home directory but I'm wondering if there is anyhow that Pro Tools could be confused where your home directory is... and there are likely ways). If so… that may be working as designed, Pro Tools keeps a lot of state information in ~/Library/Avid.
Are samples used by VIs on that drive?
Otherwise I have not seen Pro Tools grabbing drives. If not a home directory how did Pro Tools interact with the drive? You opened or saved a session there? Did the session save really finish cleanly, etc. …
Old 08-04-2022, 02:35 AM
Is it assigned something else than Transfer mode?
Old 08-04-2022, 02:42 AM
I get this from time to time regardless of PT version. Sometimes it's because PT is indexing the drive but more often it's not and even with no session open it won't release the drive and the only option is to quit PT, shrug and move on
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 08-04-2022, 02:58 AM
its2loud its2loud is offline
Same,
Been this way for me through multiple versions of PT and OS. There used to be a way to eject it from the workspace but that’s been gone for a while.
Old 08-04-2022, 03:46 AM
Yes signature correct.
What is on this drive? Your home directory? Are samples used by VIs on that drive? how did Pro Tools interact with the drive? You opened or saved a session there?
Video files is all that I reference there, not home directory or VIs or session files.
Old 08-04-2022, 03:47 AM
It's a record volume
Old 08-04-2022, 05:14 AM
Farhoof's Avatar
Farhoof Farhoof is offline
This happens when a video file was at some point linked to the drive. You have to quit PT to unmount the drive, not just close the session.
This was indeed fixed for sessions and audio files, but not for video files.
I run video files on a dedicated (internal) drive because of this and never have this issue anymore.
Old 08-04-2022, 05:32 AM
That would explain it...
Old 08-10-2022, 01:08 AM
Cryos's Avatar
Cryos Cryos is offline
Been having that too. Very odd. Happens with 2022.5 for sure .. Can't remember if it was happening with earlier iterations of 2022.xxx
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
BT Home Hub crashes on USB external hard drive eject Richardflea Storage Subsystems 1 02-22-2010 01:27 PM
external drive ( eject) ???? basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-14-2010 11:11 AM
Cannot eject drive error -50 glankrudolph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-16-2009 12:23 PM
Cannot eject removable drives while running PT Stephen Webster Post - Surround - Video 5 06-22-2007 07:45 PM
USB 2 Audio Drive Won't Eject sixstringphil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-17-2004 07:04 AM
