Delay Problem
I am a very new user of PT LE with a MBox for Windows. Put the guitar track down, but when I try to do vocals, there is a very slight delay between track in headphone and live, its disorienting. Is it supposed to work this way?
Re: Delay Problem
check your buffer under playback engine. Make it as low as you can before your system won't run.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
Re: Delay Problem
Also... with the M-Box when recording.... Mute the Rec enabled Live track, while you are recording, and use the input --- playback Mix knob on the M-box for monitoring.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Re: Delay Problem
Thanks guys, these suggestions really helped sort it out.
Re: Delay Problem
Make sure "Low latency monitoring" is activated under Operation Menu
Don't confuse kindness for weakness |
Re: Delay Problem
Low latency monitoring option isn't available on the Mbox.
Plugin Delay problem..please help | RobinWinjil | macOS | 6 | 06-17-2012 05:43 PM |
Delay problem... | Mofoman | Pro Tools M-Powered (Win) | 1 | 01-08-2010 08:08 PM |
Record Delay Problem | Shan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-08-2004 09:04 PM |
delay problem | willidrum | Digidesign Hardware & Software | 1 | 04-26-2002 05:40 AM |
DSP Problem w/ DigiRack Mod Delay | Felix | Tips & Tricks | 0 | 02-21-2000 08:24 AM |
