Apogee Symphony 64 Pcie and PT10
I have a Symphony 64 system consisting of 2 DA16-x and 2 Rosetta 800 clocked by a Big Ben.
This rig is mainly used for Logic, but also for Pt (limited to 32 I/O). The first port 1-32 is connected to the da16-x, the second port 33-64 to the 2 Rosettas. The rig is rock solid. I have now received a PT10 session at 96khz (I always receive sessions of 44.1 and 48 khz) but I cannot run the session because every time I hit the spacebar I get the following message: problem detected with audio clock. check that your clock source and sample rate are correct So i did make some trials and it seems that I cannot go higher than 48khz without getting the message above, so no 88.2, 96 and 192 as well. I also have an RME AIO pcie card with which my PT works fine. Any idea about it? I'm surprised that I cannot work at 96khz beside the limited number of i/o. Can somebody suggest a solution? |
Re: Apogee Symphony 64 Pcie and PT10
I updated the Apogee driver with the new one without any luck. Then i installed once again the old driver and now everything is back to normal.
MacPro 3.1 Osx 10.10.5 - 16 giga ram -PT HD 11.3.1 Apogee Symphony 64 system |
Apogee Symphony, symphony 64, motu 128, 3u rack case | chrisgil | Buy & Sell | 1 | 02-18-2013 10:48 AM |
Is the Apogee Symphony 64 PCIe Card a possible alternative? | meech | Pro Tools HDX & HD Native Systems (Mac) | 9 | 02-18-2012 09:16 AM |
Apogee Symphony and PT9 | forjam | Pro Tools 9 | 10 | 02-01-2011 01:52 PM |
Apogee Symphony vs HD PCIe Accel cards | DaveSB | Pro Tools TDM Systems (Mac) | 12 | 10-13-2010 08:06 AM |
HD & Apogee & Symphony | bigfatjim | Pro Tools TDM Systems (Mac) | 0 | 03-06-2007 05:36 AM |
