HEAT vs Phoenix plug...... reason to switch?
I already own Phoenix, and use it across my stems, master buss, and some individual tracks when necessary.
Any reason to get HEAT and use it instead of Phoenix, which I love the way it sounds BTW? Thanks, Mr A
Mac Pro 3.0 Ghz Quad Core OS 10.4.11 PT 7.3 HD3 x (5) 192D + (1) 192 w/ Analog card Big Ben MoL3 |
Re: HEAT vs Phoenix plug...... reason to switch?
Phoenix is great plugin. I wonder that too.
--- RECORDING Studio: Mac Pro, OSX 10.6.8, PT HD 3 PCIe, Pro Tools 8.1.1, MIX + MASTERING Room: MAC Pro, OSX 10.6.8, PT HD 3 PCIe, PT 8.1 3x 192 I/O, Digidesign PRE, UAD Octo, UAD Satellite Ultimate |
HEAT can get crunchier than Phoenix if you push it and it's adjustable by degrees in that way. It's also about the implementation of it being built into the mixer as opposed to being a per track plugin that creates s different workflow. That all, of course, comes down to personal preferences. I like the adjustably, the implementation and the sound of HEAT but that's just me. There is, of course, no substitute for trying it out yourself by simply demoing it, which is easy enough to do. I was convinced but others may feel differently.
Agree, you can get even crunchier results with HEAT but the fact it is not a plugin is both good and bad. Even if you deactivate HEAT on some tracks it will still use TDM resources and if you are running 80-90 tracks there will be many DSP´s for the HEAT "plugin". Can someone give some numbers?
I have Phoenix so for the moment I will wait to buy HEAT until there will be some news on the TDM future. Only running HD2 PCIe here and then I can´t afford to have HEAT on all channels, but the sound is great.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
I wondered the same thing and after trying them out, I had to get both.
They're different flavors and though HEAT is more integrated, you can use Phoenix on Instrument and AUX Tracks.
****************** John Rammelt Producer / Composer / Post Hajp AB old site: Soundfactory JPR |
True, but if you want to have HEAT on your instrument and aux tracks, even though what us being sent to the aux's already has HEAT on it, you can buss these tracks to an audio track and leave it in input.
Cranesong Phoenix Plug-in TDM | Dopamine | Buy & Sell | 0 | 03-16-2013 04:31 PM |
HEAT or Phoenix? | Rammelt | Pro Tools TDM Systems (Mac) | 13 | 09-01-2010 04:27 PM |
Plug In Noise from Phoenix with 2.8.5 | Scott Fahy | VENUE Live Sound Systems | 2 | 05-25-2010 03:10 PM |
Help!!! Phoenix Plug-in demo crashing my system | Shabby7 | Pro Tools TDM Systems (Mac) | 2 | 11-26-2003 10:56 AM |
Cranesong Phoenix Plug-in | slangification | Pro Tools TDM Systems (Mac) | 8 | 12-15-2002 02:43 AM |
