Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 06-15-2016, 04:57 PM
SpacekidX SpacekidX is offline
Default Failure to save Bus assignments
HI, I'm over my recent disappointment and have found a great use for Pro tools first with guitars. Unfortunately, the bus assignments don't save all the time and I have to redo them- try to save-reload-try to save. The technique that works the best is to save, then open up the mix channel (or the channel you don't have open at the time) then save again. -It triggers a save option. Then close and reopen to make sure you have your save. But I know this is a problem to report, so I am. For those with audio problems, try your interface at different rates, mine settles at 128 even though it's supposed to go lower in theory. -thanks
Old 06-18-2016, 12:28 PM
Default Re: Failure to save Bus assignments
I found a better way to save. Just do a save, then open up something to trigger a change, like the mix channel view etc. Then close the project. As long as you've triggered a change it will ask if you want to save the project you are about to close. Do that. It's worked 100% of the time for me with pulling through the bus channels.
IO assignments 8.1 Porky Pro Tools TDM Systems (Win) 8 09-08-2010 02:47 PM
Can i save non defaut controller assignments for Xpand! The Dougfather MIDI 4 03-09-2008 06:52 PM
Missing I/O Settings and failure to save Prefs PioneerPilgrim Pro Tools M-Powered (Win) 1 08-30-2007 08:57 AM
Save Session Copy In Failure... TommyT Pro Tools TDM Systems (Mac) 1 10-16-2001 09:37 AM
Boot failure- Mac OS ROM checksum failure...SCSI shaggy Pro Tools TDM Systems (Mac) 11 06-23-2000 03:30 PM
