Two plugins on screen at the same time?
Is there a way to display two plugin windows open on screen at the same time (they're not assigned to a track, just open so I can apply each as needed to some little timeline segments)? For example to have Waves L3 and Waves Q10 EQ up at the same time on screen? Again, they aren't assigned to a track, just to have both open so I can apply to a few places. I have to keep opening them one at a time.
I'm guessing when you try to open the second plugin it always takes over screen where the first one was open. Thanks. |
Re: Two plugins on screen at the same time?
Hmmmmmm if I understand your question, try Option + Clicking on plugin that is not open on screen.
You can have as many plugins on screen at the same time as you have screen real estate... that's if I understand your question. |
JC |
Shift-click on the second plugin.
Pretty much common sense, like a lot of functions in Pro Tools. Edit: if AudioSuite, I think no way to do it. Never tried.. |
Chris
Macpro 2.88-4 Gig Ram,HD2,Big Ben,Rosetta 200,Dangerous D Box,Mercury Bundle + Studio classics bundle ,C/24,2-UA 6176,U87ai,Genelec 8050 & 8020,Logic,Final Cut Studio 2,Canon hxa1(hd camera)-Macbook Pro,Mbox 2 Micro.http://www.masterlinkstudios.com/.http://www.myspace.com/masterlinkstudios |
Use quickeys.
I have mine set to CTRL-V
Pro Tools Tutorials: Mixing Heavy Rock & Metal Pro Tools 11 - Tips and Tricks Delay Explained Tracking Rock - Drums Mixing Rock Music Production with Pro Tools Pro Tools Tips and Tricks Vol. 2 Pro Tools Tips and Tricks Vol. 3 Elastic Audio in Action |
or just use window configs with a shortcut set to a marker location.
b.o.l. e
ihatetyping |
theres the red target button on the top right of each plug that does just this.
(not in Audiosuite though)
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
I didn't realize that that would work. It does.
PT10 blue screen when trying to open for 1st time. | NickRyanAudio | Windows | 14 | 06-22-2012 09:45 PM |
Blue Screen of Death every time I try to run Pro Tools :( | Victorious85 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-09-2011 09:14 PM |
Put the plugins windows on the 2nd screen cause 6031 | kinghand | Pro Tools TDM Systems (Win) | 4 | 12-24-2009 09:34 AM |
Plugins wont fit screen | dwayne00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-26-2009 05:45 AM |
I get blue screen every time I try to start le pc | cheflocher | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-25-2005 08:40 PM |
