Old 02-06-2023, 01:02 PM
Carl Lie Carl Lie is offline
Default PT 2022.12 on High Sierra?
Curious if anyone here using the latest version successfully on High Sierra.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 02-06-2023, 03:35 PM
Sardi Sardi is offline
Default Re: PT 2022.12 on High Sierra?
I literally tried yesterday on a spare machine that tops out at High Sierra. No go.
Installs but the app has the macOS line through the icon indicating it won’t launch.
I even went into the info.plist file and changed the minimum requirement from 10.14 to 10.13 and it still wouldn’t launch. There might be another line somewhere else that I’m unaware of.
So unless someone has another way to get it to run, I’d say it ain’t gonna happen unfortunately.
Old 02-06-2023, 04:55 PM
Thanks. Not surprised as it's an old OS I suppose at this point.
C
Old 02-06-2023, 08:05 PM
BScout BScout is offline
2022.7 is the end of the line for High Sierra. My High Sierra system is frozen on that. After that, Avid changed a library they compile with (must be using a later version of X Code) that prevents it from running.
2022.9 would not run on high sierra.. Stimulus2.0 Pro Tools 7 10-22-2022 10:17 AM
PT 2022.9 w/ OS 10.13.6 (High Sierra) on Mac 5,1 Ray Lyon Pro Tools 16 10-21-2022 08:05 AM
Compatibilidad de Pt 2022 con High sierra Boca_starr Pro Tools 5 06-15-2022 03:09 AM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
High Sierra jeffpardo Pro Tools 12 28 12-20-2017 09:39 AM
