Old 12-08-2011, 03:49 PM
DavidNichols DavidNichols is offline
Default Issues with H/W buffer size, using Profire 2626 and PT10 HELP!
Pro Tools will not playback the demo session. I hit play and nothing happens. When I click on the Playback Engine drop box, it gives me this popup message:
"Your audio device is configured with an unsupported audio buffer size. Please select one of the following supported buffer sizes in the device control panel: 32, 64, 128, 256, 512, 1024, or 2048."
It then opens the Playback Engine window. There is no number or drop-box next to H/W buffer size. It is completely blank. When I open the software for the Profire 2626, the buffer size is set to one of those numbers. 256 by default. I have reset it to each of the numbers listed above, and I still get the same message. HELP!
Running PT10 with M-Audio Profire 2626. 64 bit Windows 7 Home Premium, Gateway DX4860, i5-2320 processor, 3.00 GHz, 8 gigs of ram.
Old 01-01-2012, 06:54 PM
kzaiser kzaiser is offline
Default Re: Issues with H/W buffer size, using Profire 2626 and PT10 HELP!
David, I'm having trouble getting my Profire2626 to work with PT10. I have the PT10 trial installed on a very similar PC to yours but, when I launch PT10, it says it cannot initialize the ASIO device and to find another one. Well, it's the ONLY one in the 'hardware playback' dialog so I'm stuck.
Did you have any trouble installing PT10 and getting it to work? Can you describe exactly how you installed PT10 and the 2626 drivers...and any other drivers you installed?
I intend to contact Avid tomorrow but saw you got a very similar setup to work.
Thank you very much. Sorry I cannot help with your problem.
Old 01-01-2012, 07:04 PM
BradLyons BradLyons is offline
What hard drive is the session on?
Thank you,
Brad Lyons
www.howavl.com
Old 01-02-2012, 11:50 AM
panamajack's Avatar
panamajack panamajack is offline
I had to change the buffer size on my ASIO card to get the demo to play. 256 was too small. My PCI card supports a 4096 buffer, but I got assertion errors instead of the polite warning you are getting. I found the demo played fine with a buffer of 512, 1024 or 2048 (Dual CPU Opteron with 10GB memory).
Upgraded to PT10 And Now Profire 2626 Routing Issues swag74 Pro Tools 10 2 12-16-2013 01:36 PM
Help. Profire 2626 H/W buffer size no lower then 128? Venture Studios Pro Tools 9 12 12-23-2010 09:49 AM
Profire 2626 buffer size - any less than 256? risemymuffins Pro Tools M-Powered (Win) 2 10-05-2010 08:58 PM
Profire 2626 DSP Mixer buffer is locked on 64 Bits ubrnostrum Pro Tools M-Powered (Win) 26 05-12-2010 12:14 PM
PT8 + ProFire 2626 Issues 3SC Pro Tools M-Powered (Win) 4 02-09-2009 07:24 AM
