Is there a quick way to select next patch in a folder from structure?
I can't seem to find a quick and easy way to audition my library of sounds? i always thought the little up/down arrows were for selecting next and previous patches, but it just opens up the folders menu and i have to navigate through all the folders to get to my folder containing the sounds i want to audition which is incredibly slow and painful on the wrist. I tried the browser but it seems to want to create a new part each time i select a new sound!! Am i missing the obvious? a fast way to audition my library! Chris
Re: Is there a quick way to select next patch in a folder from structure?
In the upper left corner of the RTAS plug in window there are plus and minus symbols in between the "Default Name" and "Compare". Is that what your looking for?
Digidesign 003R+PT 2020.12.0, Gigabyte GA-Z97X, CPU INTEL i7-4790 4.0Ghz, CORSAIR DOMINATOR 16GB; ATI Radeon™ HD 5450 PCIe Multiple WD Caviar Black 2Tb Spinner Drives; 1 PPA 80GB 1394 Firewire Oxford 911 PYRO PCI64R2 3 Port Firewire Card (PCIe) Antec 300 case. PSU 600W, Windows 10 Home. |
That would work except for the fact that the Structure content does not come with the patches saved as plugin settings. You would have to go through the process of loading each patch and then saving it as a plugin setting. Once you have them all saved, you would then be able to scroll through them quickly and even auto advance them in the settings window. Check out the little button just to the right of the + button.
Send me an email as I've made presets.
You may have to direct Structure to your patches depending on where they are located on your hard drives and then re-save Save Settings As... (Command/Control+Shift+S) the preset and you should be fine. Hope this helps. I've just posted these to the Air Blog Patchbay.
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2. It is what it is... ScrewMakerMusic |
check the air user blog russ did a video on that
I was wondering the same thing. auditioning our library is difficult especially as our library is quite large now and many folders deep.
So is there a way to audition through all the patches in a sounds folder without having to re-navigate to the folder again? i couldn't see any video on the blog about this did i miss it somehow. Jez |
Select Waves 7.1 Plug-Ins Folder | DR_LI | Pro Tools M-Powered (Mac) | 2 | 10-06-2012 01:12 AM |
Select Waves 6.1.1 Plugins Folder | sleazedc | Pro Tools M-Powered (Mac) | 5 | 07-05-2012 09:10 PM |
Structure 1.1/Structure Free Sounds/Sample folder | DTheone | Virtual Instruments | 9 | 03-29-2011 06:25 PM |
select Waves 6.06 plugins folder in 8.0.1 | a7bull | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 10-17-2009 10:47 PM |
Structure Assigning patch with the Triangles next to patch name? | VanAmp | Virtual Instruments | 1 | 09-06-2008 09:45 PM |
