Insane Phasing Issues
Ok so I am having some issues regarding samplers in PT LE. 7.3.1cs7.
In Battery 3 I load 1 sample. I hit preview in the browser of Battery and the file plays back completely normal. I then drag the sample to a cell and trigger using my controller and phase mania 08 begins. I go through the options to look for anything suspicious and notice nothing that makes any sort of difference. I then fire up reason 4 and load the same sample into the NNXT (preview in the NNXT and sample plays back fine) As soon as I trigger the sample it its completely out of phase. I then upgraded to cs7 and same problem. I have restarted the machine several times and still same proble. I have a project I need to start using a sampler and I can't afford to have this happen right now. I'm tearing my hair out. Any ideas? I have also obviously tried different buffer and sample size settings and that doesn't do anything either. My system is an Athlon 64 X2 Dual 4600+ 2.41 GHz, 4 gigs ram. Thanks |
Re: Insane Phasing Issues
Could you give us a little more info on what you're using to trigger the samples? Is it possible your controller is double-triggering?
I'm using the M Audio AXIOM, via the usb port
LOL, I just figured it out thanks to you, I had the wrong midi input selected. It was double triggering. Hrmmm strange.....After I reassigned the midi input The samples triggered were sounding normal till I recorded a take. After recording the take and playing back I'm getting the phased out sounds again. And now when I trigger sounds I'm getting weird phasing. I don't get it.... |
What do you mean exactly by 'weird phasing'? Is it slowing down/speeding up? Or are there two samples playing?
Possible Phasing Issues with Low Drums! | tunaman14 | Virtual Instruments | 0 | 09-09-2012 01:09 PM |
Phasing issues? | tobbenos | Pro Tools 10 | 7 | 11-14-2011 02:51 PM |
Phasing issues with groups? | Limelight | VENUE Live Sound Systems | 14 | 10-01-2010 10:02 AM |
PHASING ISSUES | richsorr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 08-03-2004 12:44 PM |
Phasing issues w/aux channel | radioking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-01-2004 09:14 AM |
