Mac HFS+ Disk Support not installed
After installing PT 10.0 from my original installer, the "Mac HFS+ Disk Support" utility has not been installed in Windows 8. I have tried several installation permutations including installation of all features as well as installation of just the driver.
After installation each time, the driver does not run nor can I find it in the Start Menu or the Programs and Features section of the Control Panel. This is strange because in a previous Windows 8 installation (which I had to remove) the HFS+ driver was successfully installed and worked as expected. If anyone has encountered a similar problem and found a workaround, I'd greatly appreciate the tip. Here is the relevant information I could find from one of the install logs: ----------- MSI (c) (D4:B0) [00:20:44:189]: Note: 1: 1324 2: .HFS+ Private Directory Data 3: 1 Info 1324.The path .HFS+ Private Directory Data contains an invalid character. MSI (c) (D4:B0) [00:20:55:472]: Skipping action: UninstallHFS (condition is false) InstallShield 0:20:55: Saving properties: ADDLOCAL="HFSMac" AFTERREBOOT="" ALLUSERS="1" ALLUSERSPROFILE="C:\ProgramData\" COMPANYNAME="" DATABASEDIR="C:\Program Files (x86)\Avid\Pro Tools\Database\" DIGI9FDLR="F:\~Software\~Installers\Pro Tools 8\ADAMO\DigiDesign\" EXECUTEACTION="INSTALL" EXECUTEMODE="" FILEADDDEFAULT="" FILEADDLOCAL="" FILEADDSOURCE="" INSTALLDIR="C:\Program Files (x86)\Avid\Pro Tools\" INSTALLDIR.C9C35FC7_5AEE_4C1E_8BD2_80ED9FA87FFF="F :\" INSTALLDIR.DC6C7538_1E2E_429F_849B_9102EEE51C5F="C :\Program Files (x86)\Avid\Pro Tools\" INSTALLLEVEL="100" ISFOUNDNEWERPRODUCTVERSION="" ISSHOWMSILOG="" ISX_SERIALNUM="" LAUNCHPROGRAM="" LAUNCHREADME="" LIMITUI="" LOGACTION="" MS.8C0C59A0_7DC8_11D2_B95D_006097C4DE24="C:\Window s\SysWOW64\" MSIENFORCEUPGRADECOMPONENTRULES="" MSIINSTANCEGUID="" MSIPATCHREMOVE="" NOCOMPANYNAME="" NOUSERNAME="" NSINEWINSTANCE="" OLDAUDIODRIVER="" OLDHD9DRIVER="" OLDPTHD9ACTION="" OLDPTMP8FOUND="" OLDPTMP9FOUND="" OLDPTSE8FOUND="" OLDPTVERSION="" PATCH="" PRIMARYFOLDER="" PROMPTROLLBACKCOST="" QUICKTIMEFOUND="C:\Windows\SysWOW64\QuickTime.qts" REBOOT="ReallySuppress" REINSTALL="" REINSTALLMODE="" REMOVEOPTION="1" RESUME="" SEQUENCE="" SHORTFILENAMES="" TARGETDIR="F:\" TRANSFORMS="C:\Windows\Installer\{B8A91DE4-8279-4AED-990F-40852520CC9F}\1033.MST" TRANSFORMSATSOURCE="" USERNAME="William" USERPROFILE="C:\Users\William\" WMVCOREFOUND="C:\Windows\SysWOW64\wmvcore.dll" IS_PREREQ="Reboot" Action 0:20:55: Installing Pro Tools HFS+ Disk Support 8.0.6.52. Installing Pro Tools HFS+ Disk Support 8.0.6.52 InstallShield 0:21:00: *** Prerequisites complete; return code 0 MSI (s) (1C:78) [00:21:00:103]: PROPERTY CHANGE: Adding ADDLOCAL property. Its value is 'HFSMac'. MSI (s) (1C:78) [00:21:00:214]: Feature: HFSMac; Installed: Local; Request: Local; Action: Local MSI (s) (1C:78) [00:21:00:215]: Component: Regx86AvidHFS; Installed: Local; Request: Null; Action: Null MSI (s) (1C:78) [00:21:00:215]: Component: ReserveCostHFSComp; Installed: Local; Request: Null; Action: Null MSI (s) (1C:78) [00:21:00:218]: Component: __Regx86AvidHFS65; Installed: Null; Request: Null; Action: Null MSI (s) (1C:78) [00:21:00:218]: Component: __ReserveCostHFSComp65; Installed: Null; Request: Null; Action: Null MSI (s) (1C:78) [00:21:01:373]: Skipping action: SetAvidHFSx64 (condition is false) MSI (s) (1C:78) [00:21:01:669]: Executing op: FeaturePublish(Feature=HFSMac,,Absent=2,Component= s260Q3jk19L(jMmGsi2bZ*w*qn,I1?RhfS,n&_}R) PublishFeatures: Feature: HFSMac Property(S): ADDLOCAL = HFSMac Property(S): IsPrerequisiteFeatures = Application,Effects,HDx,HFSMac,PLUpdates,Video |
Re: Mac HFS+ Disk Support not installed
Try installing pt 9 first
Installed HFS+ Support and now all Mac drives unreadable?! | soundonsound | Pro Tools TDM Systems (Mac) | 2 | 05-20-2008 08:02 AM |
HFS+ Disk Support | theaero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 05-13-2008 02:53 PM |
installed 6.9 ...update faders..disk allocation? | skyking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-22-2005 08:21 AM |
For you guys who got PT6 installed already: Does it support Rewire? | Raki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-14-2003 06:14 AM |
noise after new hard disk installed | nehpyh | Digidesign Hardware & Software | 1 | 10-03-2002 07:17 PM |
