ProTools crashes in new MIDI track...
When I try to change the patch on a new MIDI track (with the "program button") either in Edit or Mix, PT crashes without warning. On the tracks that already have a patch specified, i can open the program change window and select a different patch, without a problem. It only crashes on new MIDI tracks, when the button says "none".
I am using PT 6.7 on a G5. My MIDI device is a Yamaha PSR 530 through an M-Audio Uno USB interface. Luckily I was able to find a PSR 530 midnam file, so that is the file the program button is trying to load. I just installed Amplitube, Reason, and Sampletank, and I wonder if any of those have anything to do with the problem. Thank you!! Kevin |
Re: ProTools crashes in new MIDI track...
Please update to Pro Tools LE 6.7cs8, which has a fix for your particular problem.
Index of all Pro Tools CS Updates |
I have same problem with digi001 and P.T. 6.4 WITH LAST UPDATE !!!
What Now,DIGI? THX |
Thanx for your help,
-no support, -no ideas, -no music -no money back -no-thing One more - thank you... |
Shame69 - it's always best to start a new thread unless your issue is specifically related to the current thread (same PT version, hardware, etc.).
Have you tried all the steps in the 'General Troubleshooting' at the top of the Pro Tools LE/WinXP forum? You should also try trashing preferences files - do a search on your computer for files ending in .ptp, delete them, restart and try everything again. Please let us know if this resolves the issue for you. |
Structure Free crashes ProTools LE when loaded onto track | pjanocha | Virtual Instruments | 1 | 11-01-2007 01:45 PM |
Adding a midi track crashes protools immediately | citi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-19-2007 09:30 AM |
Creating MIDI track crashes PT | nanners | MIDI | 2 | 06-06-2007 03:50 PM |
Creating a Midi track crashes PT! | wehavethefacts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-24-2005 06:20 AM |
HELP! PT crashes when I create a new midi track... | Diezmilcometas | MIDI | 1 | 04-14-2005 09:56 AM |
