Old 07-19-2012, 03:11 AM
tvjorg tvjorg is offline
Default momentary un-group
Does anyone know a shortcut for momentary de-activating or suspending groups? Ex. when doing fades with the mouse on a specifick track belonging to a group, but doing it without affecting the other tracks in the group?
Thx
Mac Pro 1.1, HD3, 2x Digi192, 2x Digi Pre, Icon D-Control 16 faders ES, PT 10.3.2, Dangerous 2Bus, Waves Mercury, Genelec 1025A Main Monitors
http://www.eyeball.dk
Old 07-19-2012, 05:36 AM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: momentary un-group
Thx
There's a button on my d-command, labeled Susp.Grps.
Isn't it that what you need ?
Also, holding ctrl. modifier pressed might work, too (like for soloing a grouped channel). But I'm not sitting in front of the d-command.
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 07-19-2012, 07:57 AM
Thank you,
i was just hoping for a method like holding down a cap while dragging the fade-boundaries with the mouse.
But cmd+shift+g does the job. (like the Suspend Groups button on the console)
Vielen Dank.
Old 07-19-2012, 09:32 AM
Drew Mazurek's Avatar
Don't forget that you can make a group be a Mix Group only and then the groups won't affect the Edit functions.
www.drewmazurek.com
Old 07-19-2012, 01:26 PM
That's why I'm using VCA masters for controlling volume of mix groups in 99% of all my PT-sessions.
Imo it's much easier to ride the VCA-master for a certain group if one wants to automate all group members at once because it still leaves the option open to ride individual channels though.
Of course Automation Mode has to be unchecked to make it work.
Cheers, STeff
Old 07-19-2012, 02:53 PM
Vielen Dank.
Keeping ctrl pressed while moving a fader within a mix group works too.
Cheers, STeff
Converting latching to momentary? adamqlw Eleven Rack 3 10-12-2012 09:47 PM
momentary link feature pmueller VENUE Live Sound Systems 1 01-21-2009 03:29 AM
strange momentary drop outs and volume curves peiman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-28-2006 12:06 PM
Automating mutes-stuck in momentary mode??! mtung Pro Tools TDM Systems (Mac) 2 10-24-2005 04:34 PM
Small momentary freezes in Pro tools Jared3 Pro Tools TDM Systems (Mac) 6 12-08-2000 05:44 AM
