iZotope RX4 Adv and automation in PT10
Working with RX4 Denoiser instantiated on several tracks in a project and with automation enabled on all parameters, I wonder what happens with the noise-profile. To me it seems like its only the last learned noise profile that is showed and used. So playing back clips earlier on the timeline doesn't recall those clips noise profile.
Am I doing anything wrong? Thank you for attention.
Mac Pro 1.1, HD3, 2x Digi192, 2x Digi Pre, Icon D-Control 16 faders ES, PT 10.3.2, Dangerous 2Bus, Waves Mercury, Genelec 1025A Main Monitors http://www.eyeball.dk |
Re: iZotope RX4 Adv and automation in PT10
Realtime automated de-noising olny makes sense with the dialogue denoiser not the other one for the reason you mentioned.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Hi Frank,
thank you for your reply. I don't expect it to be automatic realtime. Perhaps I didn't explain it well. Im doing the learn-function, tweaking the other parameters, and then save all the parameters - Write to all. This saves all settings, but not the learned noise-curve. And this doesn't make sense. Do you follow me?
I would use the denoiser as an Audiosuite plugin so that you can apply the noise reduction directly to the audio rather than trying to automate the parameters and do it in real-time. Just copy the playlist on the track first and you'll always be able to go back to the audio pre noise reduction if needed.
Thank you James,
yes, thats the way I have done it, since RX2, and it works. I just wonder why it isn't possible to save the noise-profile along with the other parameters - but off course there must be a good reason for that. Best Tom
Maybe the developers at iZotope never thought it through that way. Being able to save the noise profile as a snapshot and being able to automate those snapshots would serve your workflow perfectly.
iZotope Insight crashing PT10 | noiseboyuk | Post - Surround - Video | 5 | 06-16-2015 11:46 AM |
Pan Automation not playing correctly in PT10 | WernerF | macOS | 31 | 03-27-2015 10:55 PM |
PT10 to PT10 via AAF, but there's no volume automation? | npod | macOS | 2 | 03-04-2013 02:30 PM |
PT10 automation question. | benherron.rrr | Pro Tools 10 | 6 | 11-21-2012 12:52 PM |
PT10 Plug In Automation Help!! | Bantom | Post - Surround - Video | 1 | 04-22-2012 07:29 PM |
