Go Back   Avid Pro Audio Community > Pro Tools Hardware > MBOX Studio
  #41
Old 10-20-2022, 07:31 PM
noah330 noah330 is offline
Default Re: New desktop Avid Interface
Originally Posted by massivekerry View Post
That's appreciated. If they have any info they're willing to share on future paths for HD Native users (since the current card appears to be a s***show in PCI chassis with the Mac Studio, plus it's end-of-life anyway), that'd be a big help.
Is an AVB remote possible? Do you need an AVB hub (don't know if that's a real thing) for something like that? Carbon's "ownership of the Ethernet port" is one of the things that has had me skeptical about it.
My HD Native card runs flawlessly with my Mac Studio. What chassis are you using?
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
  #42
Old 12-31-2022, 10:32 AM
Bubbalou88 Bubbalou88 is offline
Default Re: New desktop Avid Interface - MBOX Studio
I just bought the MBOX Studio a week or so ago. It is my first interface. I like it so far but have a lot to learn about recording with a DAW. My only other was a TACAM Portastudio 008X. I am liking it so far. My two issues the Foot Switch working on Starting/Stopping a Recording Avid say’s coming soon and the Bluetooth output for use with Headphones. They seem to only work if your computer connects to the Headphones. Why don’t they make the interface do it since that is where they will be used? The button is on the interface but documentation seems to say you must connect to Computer first (if I read correctly) If anyone knows the answer please way in here.
MSI GE66 Raider 10SFS I7 2.60Ghz 64GB DDR4 3200 Ram
Windows 11 Home 64 Bit
MBOX Studio Audio Interface
Pro Tools Studio 2022.12
  #43
Old 12-31-2022, 10:41 AM
dominicperry dominicperry is online now
Bluetooth headphone connectivity is a gimmick. I'm surprised Avid included it.
If you are tracking (i.e. recording) then the latency added by Bluetooth is about 150ms - completely unusable.
If you are just mixing, then there an no Bluetooth codecs which support lossless encoding, meaning you are always listening to a sub-optimal version of the mix.
I can't directly answer your question as to why it isn't working, I'm afraid.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
  #44
Old 12-31-2022, 11:19 AM
junkgear's Avatar
junkgear junkgear is offline
I’m not sure where you are getting that your computer needs to connect to the headphones. Here are the instructions from the manual:
Pairing MBOX Studio with a Bluetooth device (speaker, headphone, or other)
3 Put your external Bluetooth speaker or headphones into Bluetooth pairing mode. When the connection is established the MBOX Studio Bluetooth (output) button stops flashing and lights blue.
4 To disconnect Bluetooth press and hold the MBOX Studio Bluetooth (input) button for 2 or more seconds. Or turn off Bluetooth on your source device
Before doing this, Press and hold the Bluetooth button in the Output section for 2 seconds. The Bluetooth (output) button flashes blue.
Will
System Details
  #45
Old 01-01-2023, 01:36 AM
Dominic
Thanks, didn’t think of that aspect. I will just use a cable with them
  #46
Old 01-01-2023, 07:55 AM
basslik's Avatar
basslik basslik is online now
That was good information regarding Bluetooth.
I'm surprised it only has 8 visual meters on the unit as well.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
  #47
Old 01-01-2023, 05:10 PM
Many other small interfaces I have seen have 2, 4 or none. Most of the meters are in the DAW so unless you have a huge professional unit this will be a moot point, correct? I guess they were trying to make bang for the best buck for casual or semi professional users which is perfect for me.
  #48
Old 02-24-2023, 06:30 AM
sadironmusic's Avatar
sadironmusic sadironmusic is offline
Bluetooth connectivity is for playing back reference stuff from phones or using Bluetooth connection to check mixes. The vast majority of listeners are going to be listening through a Bluetooth device of some kind. Might as well make sure the mix sounds OK there before sending it into the world.
  #49
Old 03-09-2023, 09:30 AM
Swivel Swivel is offline
I have three already
THREE?!
"I think it's all about having a great time when you're recording cause when you're not, people can hear it."
Dave Cobb
randevickagency.com
Presonus Studio 1810c and Mbox 2 Pro interface albee1952 Buy & Sell 1 01-23-2022 05:42 PM
I want to efficiently transfer my home studio from desktop pt 6.4 to laptop pt 11 Spikerama 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-02-2014 09:36 PM
Help regarding Avid Recording Studio & Mbox mini HK44 Pro Tools M-Powered (Win) 1 03-29-2011 07:00 AM
Avid Recording Studio vs Avid MBox Mini 2 vpg0002 General Discussion 7 03-20-2011 07:52 AM
PTLE 6.5.3 (Avid Studio Mbox) - RAID Problem TEJW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-17-2005 07:00 AM
