REVERSE.
I know Linkin Park reversed an acoustic
guitar progression, then chopped up the chords and re-arranged them in the original order for ther radio single thats been out from the new album. Can anyone give some tricks/effect using reverse in different ways with audio? [img]images/icons/blush.gif[/img] |
Re: REVERSE.
i have reversed a section of music and added delay or reverb, then flipped it back forward so the effect is heard before the music. i have added "backward masked" vocal samples to songs. sometimes a riff sounds almost the same backwards as forwards. i have started a riff backwards and then 1/2 way through switched it forwards. backwards drums sometimes make a pretty cool beat. what are you looking to do?
+CORPORATE WHORE+ www.8mmOverdose.com www.Tondra.com www.UnderworldEvents.com www.JagerMusic.com www.MonsterEnergy.com |
Re: REVERSE.
record some speech or singing
reverse it learn how to speak or sing it backwards record THAT reverse it Sounds very weird.
Quad 2.5 G5, 4.5G RAM |
Re: REVERSE.
dabasstard's gonna love this one....
Okay, so I wanted this bass line tricked out. So I played it normally then reversed it so I could learn how to play it in reverse. Once I learned it I then recorded it then reversed it. I now have the right notes played in the right order with this weird backward kind of sound to it. |
Re: REVERSE.
Re: REVERSE.
** kewl tips, keep em coming.
Re: REVERSE.
Re: REVERSE.
You can do it with the Speed plugin.
Re: REVERSE.
I love using Reverse for some things. I used a combination of Reverse and slide to create this 'Stratosaurus':
http://basstardz.dhs.org/roy/mp3/_Ot...osaurusRex.mp3
rh music |
Re: REVERSE.
Wandering Star, you got the effect right,
Just reverse the phrase, add a light reverb not too strong or words will overlap reverse style and it will sound bad(usually), just use a light reverb, then reverse it again. I beleive Cubase has something similar, but its an effect that does it all in one spot, its called "Espacial" or something. Anyone know that for fact? Hope that helps. =-Ben
Ill suffer winter alone; ten thousand miles from home... |
Reverse | Mentalist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-17-2005 12:17 PM |
Reverse Reverse? How They Do That? | tomhartman | Pro Tools TDM Systems (Mac) | 6 | 02-03-2005 07:34 AM |
reverse | Eless | Pro Tools TDM Systems (Win) | 1 | 12-20-2004 08:36 PM |
Reverse | souldier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-23-2002 03:38 PM |
Reverse? | Transducr | Tips & Tricks | 4 | 11-22-2000 08:49 AM |
