Intel Chipset compatibility
The compatibiliy specs for the digi002 system on the digi website recommend the 850/850e or 845/845e Intel chipsets, yet, you can't buy a new computer with these older chipsets in them. Does anyone know if this is a minimum version (i.e. any chipset higher that these would be OK?
Re: Intel Chipset compatibility
I have herd of people using the newer Intel chipsets with success, although DigiDesign doesn't officially support them yet.
digi should step up to the plate
and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section digi should step up to the plate and revise the chipset section |
Digi tech support told me that the chipsets listed were the only ones that they have tried and have worked successfully with the 002. That doesn't mean that they are the only chipsets that will work, it means thats the only ones that they tested! We are all beta testers. Welcome to the club!
Digi001 Intel P965 Chipset compatibility | mbkorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 03-28-2011 11:00 AM |
Intel 5500 Chipset compatibility Xeon Nehalem E5504 | E3GH75 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-06-2009 03:09 AM |
Intel Q35 Express chipset: PT compatibility? | sonicblue57 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-12-2008 07:14 PM |
Compatibility with Intel i915P chipset | localmotion411 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-16-2005 04:30 PM |
New chipset from Intel compatibility | Antonio Tarantino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-24-2003 08:39 PM |
