How to solo effect return in PT ?
Hi, I make new aux track and insert effect plug ins ,reverb with setting 100% wet . After that I use send to send vocal track to that aux .Then I insert EQ to aux track .How can I solo and listen to EQ on the aux track,wet signal,only .There 's no sound when I solo the aux track because I have to make solo isolate on vocal track .If I make a solo isolate on vocal track ,How to listen only wet signal on aux track .......?
Re: How to solo effect return in PT ?
Well, you could temporarily change the output channels of the vocal track to something other than the reverb return, or, temporarily change the send from post-fader to pre-fader and pull the vocal fader all the way down, both of those will do the trick. Good luck!
------------------ Joe Milner Puget Sound Los Angeles |
What Joe says. Make the vocal track's send pre-fader and then solo the aux channel with the reverb/eq. You don't have to do anything else.
It would be nice to let users assign an "effects return" attribute to an aux input, or maybe to a bus or bus pair, which would prevent muting of material being sent down that bus when the effects return is soloed. A channel with a send would still be mute, but the mute would be post-send.
That´s the case with Logic Audio Platinum...
Peter [This message has been edited by Peter Duemmler (edited December 27, 2000).]
http://www.merlinsound.de |
Since this an 8 year old thread, has anything changed now in PT 7.4? How could I setup my auxes to solo the wet signal?
PT 7.3.1cs2 TDM HD3 PCI HP xw8400 192 i/o |
Solo-safe the auxes (Command-click the solo button on Mac), and set up pre-fader sends on the source tracks. Raise the send faders to desired amount, mute the source tracks, and voila.
The only way to solo only the wet returns of post fader sends is to use the dedicated solo bus function in PT which requires the use of separate outs. This is handled perfectly with ICONs but it a bit more tedious without one.
Hey Ubermeister, who taught you that one?????
c24 send return to ext effect | BMSS | ICON & C|24 | 4 | 04-07-2011 03:36 PM |
what to listen to ?? soft return or in return ? | martin coria | Pro Tools M-Powered (Win) | 0 | 10-13-2010 04:11 PM |
How to solo reverb return? | bad jitter | Post - Surround - Video | 3 | 07-04-2009 05:37 PM |
Return/Enter key won't return to 0:00 on Pro Tools LE on Mac | marcnyc | Pro Tools M-Powered (Mac) | 2 | 08-31-2007 02:29 PM |
simple routing question/mbox/effect send and return | iamaracinghorse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-22-2007 03:50 PM |
