compatibility between G5 and intel...
I am having issues with certain sessions not wanting to open on my G5 tower. I'll have a session that I am working on within my Macbook Pro and want to open on my tower and it will crash at launch. Not sure why this is as they are both running PT8 and are not using any different plugs from one another... All are current with PT and even if I save the session as a copy or save under a different name it still does it. Anyone else having this issue? My G5 is a 1.8 dual and the MBP is a 2.26 intel duo.
www.klearlightstudio.com |
Re: compatibility between G5 and intel...
Is it possible that you're having permissions issues since it's between two different computers and, most likely, two different user IDs? Are the sessions on an external drive? Try doing a Command-I (Get Info) of your external drive. In the bottom left corner of the INFO window is a check box that says "Ignore Ownership on this volume"... CHECK THIS. Reboot and try again.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Sorry, I just realized i posted this in the wrong forum. Should be in LE....
compatibility between G5 and intel... | indoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 03-09-2010 03:34 PM |
Intel to PPC Compatibility Problems | bardace | Pro Tools TDM Systems (Mac) | 2 | 02-13-2009 03:12 PM |
Intel 865G compatibility | BTK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-15-2003 07:46 AM |
Intel Chipset compatibility | kshem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-03-2003 07:42 PM |
New chipset from Intel compatibility | Antonio Tarantino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-24-2003 08:39 PM |
