Click the protools icon protools does not load!
I have downloaded all the proper updates i belive. I have a quad G5. M powered worked just fine, then i tryed to load LE and im having. Like i said i click on PTs and it bounces a few times but the program will not load. I have tryed reinstalling, all the updates that i belive were right. This is also with the M-Box 2, not sure if that makes a difference. Thanks for the help.
Re: Click the protools icon protools does not load!
I'm having the exact same problem with my HD|2 system. Please help! I have someone waiting in the lounge to get started on a session!
Thanks! |
log out of your profile- log back in and click on the pt icon right away- usually a quick fix
Go to the Digi site and get the prebinding script and the tech support tool. I think your problem needs the prebinding script.
Chris Neal :: South Plains College .: Program Coordinator & Asst. Professor in Sound Technology .: [email protected] .: Pro Tools Certified Instructor .: Pro Tools Expert Certified in Music |
Thanks! I actually tried the prebinding script, and it didn't fix it. I think I have done more damage by trashing some other things while trying to fix this problem. I can't open System Preferences now, my clock has disappeared, and the blue finder icon in the upper right corner next to the clock is flashing.
I'm downloading the OSX Combo 10.4.10 update to see if I can fix the OS problems, then I'll try running the prebinding script again. I downloaded some updates earlier today, and that's what started the whole problem. I figure I can't make it any worse by downloading this update... Any clue how to fix the OS problem if the update doesn't work? Thanks for your help! This is frustrating... Daniel |
10.4.10 has known issues and PT incompatibility.
Is there a way to get back to 10.4.9?
Try a google search. I don't want to make you go through any unnecessary steps. Maybe someone has a good list of steps.
I think you need to boot from an earlier version install disk and reinstall from there, but maybe someone has an easier/better method for you.
If I do that will I lose Pro Tools and the plugins I have installed?
I think you can choose a clean install versus one that should preserve apps etc., but you should be prepared for the worst.
Windows ProTools 10 freezes at the click of "Install ProTools 10" | JakeStrauss | Windows | 1 | 10-01-2012 08:53 PM |
Question Mark instead of ProTools Icon? | enveemusic | macOS | 2 | 02-14-2012 08:56 AM |
The Bouncing Protools 9 icon | roberts | macOS | 1 | 12-16-2010 09:58 AM |
Protools D-control V.S. SL9000J / Protools ICON | gclef101 | ICON & C|24 | 5 | 07-30-2005 04:45 PM |
ProTools aqua icon for dock! | 8trackmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-19-2003 01:28 AM |
