Old 01-24-2006, 08:15 AM
donrey donrey is offline
Default Multi Monitor set up
So here is what I would like to do with my procontrol:
I would like to use all of the outputs from the procontrol without using the slate feature since this doesn't allow one to use the multi monitor feature.
example... I have three sets of monitors, and a headphone distribution system. Currently, the main switch is controlling Genelec 1031a's, the NS-10 are set up on the alt 3-4 and the production monitors are set up on the ALT 5-6. There is a free pair of outputs. I have found the only way to use these is to set up the procontrol in the slate function. Is there another way to have these outputs be active so that I can use the multi monitor feature? This output doesn't need to be controlled since the headphone amp has an input knob so it can be direct.
Old 02-14-2006, 09:03 AM
lightning ad lightning ad is offline
Default Re: Multi Monitor set up
could you not just set up a headphone feed on outputs 7/8 or use a bus channel set for the headphone mix? You don't really need desktop control of that feed as you say there is a control knob on the phones amp.
adam taylor
video editor/dubbing editor/sound design/motion graphics/compositor
United Kingdom
Does 10 still have the bug if Input Monitor is on a multi-channel track Craig F Pro Tools 10 0 05-05-2012 06:17 PM
Multi-Monitor Setup: Detached/Floating Window jrlanglois Pro Tools 10 7 12-29-2011 01:06 AM
multi-monitor systems edriver Pro Tools M-Powered (Win) 9 03-17-2008 11:51 AM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
Multi Monitor and windows Eric Heil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2002 09:50 PM
