administrator required to run protools?
Im currently setting up a lab of 16 g5s with mboxes. As well as protools there are other music-related software packages installed. The lab is for use by students at our college, and therefore i want to have control over user limitations/permissions etc. However, i've just discovered today that Pro Tools Le (latest) wont run unless you're logged in as an administrator.. there goes the system security! Why is this so? Has anyone worked around this problem or know of a solution? |
Re: administrator required to run protools?
Yes, the solution is 6.2.3b1 beta update. It lets you run ProTools without being a Sys Admin, and was designed for facilities like yours. You can get it from the LE 6.2.3 download page. We've been trying it for a few weeks now, although there did seem to be some problems with core audio (Reason in particular) but I think that is common to all version of 6.2.3 not just the 3b1 beta.
Studio: Mac Pro Trash Can 2.7 Ghz, 32Gb RAM, Sonett xMac Pro Server, HDX 22.12, S6 M10 24 Fader, Rednet 5,1 and 4 Live: MBP 16" M1 Max i7 32Gb RAM, |
Thanks for that. I did try that update yesterday (6.2.3) and had major issues with core audio and reason, so i went back to 6.2.2... i cant win either way!. I hope digidesign address this problem asap. |
It's not the 6.2.3 update, you need to download the 6.2.3b1 update.
That's if you want it to work. |
Ok, got it working much better now and without admin rights. Had to install 6.2.3 before putting the 6.2.3b1 version on. Reason seems to be happy now (and so am i!). Thanks for your help!. |
Let me know how you get on with Reason, Core Audio and the beta 6.2.3.
It seemed to work for us at the start and then Reason started to quit all the time untill we put it back to playing out through the built in audio.
Happy to hear you are up and running.
hi marty, only just got around to looking at the forum today and saw your post.. we're having the same problem, if you run reason stand alone (using coreaudio driver) it will crash everynow and then, but when you use it with PT through rewire its stable as. Im just hoping this new coreaudio driver release will fix the problem. I dont suppose you know if the latest LE update supports multi users who are not admin, or do we have to wait for a beta release? |
ProTools Controllers (suggestions required) Yamaha 03D ??? | Daddo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-06-2008 11:48 AM |
ProTools only with administrator rights? | jl29 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-25-2004 08:00 AM |
Why is Administrator access required in OS X versions?!?! | tcassel | Pro Tools TDM Systems (Mac) | 10 | 07-11-2003 02:33 PM |
XP Home... log in as administrator to install Protools LE? | Siberian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-17-2003 10:10 PM |
Can't load Protools 5.01 with DAE/DSI 5.1 "TDM MIXER REQUIRED". How Can I get that? | beerbr | Pro Tools TDM Systems (Mac) | 1 | 02-23-2001 11:13 PM |
