Old 11-22-2009, 02:43 AM
Luke K Luke K is offline
Default Simple monitoring levels setup question
This is a question i have never got around to asking..even tho it would make things easier...
When i track say a singer...is there a way to set up levels with them singing along to the instruments (without having to record enable and do a take??)
Thanks,
Luke K
Intel Quad Core 2.83 ghz
4 Gig Ram
2x 1Tb 7200rpm seagate Hard Drives
Pro tools 8.0.1
003 Rack
Mackie Mr5 monitors
Windows Vista Home Premium Sp1
Old 11-22-2009, 08:32 AM
scottedog scottedog is offline
Default Re: Simple monitoring levels setup question
Sounds like you're looking to change input monitoring...alt + k.
Scott.
ScottedogStudios on ReverbNation
Old 11-22-2009, 09:47 AM
scottedog hit it. You can also feel free to roll in record for level setting. If you hit Ctrl-Z right after you hit STOP, the new recording is canceled and no audio is kept from that pass(this cannot be undone BTW).
Old 11-22-2009, 11:47 AM
Ben Jenssen's Avatar
Command-period during recording accomplishes the same thing.
Old 11-22-2009, 11:23 PM
BScout BScout is offline
I was under the impression that Command + Z will keep the audio file (though it will disappear from the session and region list it will still be on the hard drive.)
Command + period would make it like it never happened (no file on hard drive, playlist, region list.) We used to have a rule at a studio I used to work at that Command + Period was never allowed during tracking since there was absolutely no way to go back in case a good take was removed while Command+Z was allowed since it'd keep the sessions clean but in case of catastrophe, you could find and reimport the audio file. This was true up to version 6; haven't seen if it works differently in version 7 or 8. (and of course, command period only works while the transport is recording while command + z needs to happen after stopping recording)
Help! Probably simple Newbie Question re: Monitoring in Headphones while Recording ETThompson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-19-2012 06:39 AM
Input levels - Simple question jjhuntfox Pro Tools TDM Systems (Mac) 3 03-14-2008 06:36 PM
Question about final levels and monitoring mahler007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-26-2006 02:24 PM
Question re post levels monitoring Trillium Lane Labs Post - Surround - Video 13 10-03-2003 02:09 PM
Simple Pro Tools monitoring Question emilano Tips & Tricks 3 05-12-2001 11:13 AM
