TL Space True Stereo Routing Issue - HELP
Hi List,
I already talked to digi´s tech support but they werent able to reproduce the problem i have with the tl space tdm plug in. even their solution advice couldnt fix the problem. i wonder if anyone else can reproduce what i hear and observe. i would be glad if u guys find the time to try this. (tdm systems prefered). sorry for my bad english. 1> open 1 mono-track and insert signal generator with any sort of noise(white noise is most comfortable to your ears 2> open 1 stereo bus and insert the "TL SPACE LARGE TRUE STEREO" plug in. Route to LR 3> open the tlspace plug in window. now turn the panning of monotrack with the Signal Generator hard left and hard right 4> you should hear the reverb moving to the sides by turning the panning as it should. 5> now change the tlspace plugin to "TL SPACE MEDIUM TRUE STEREO" and start from step 3 again. now look at the plugin window and listen... what u hear and see ? im realy curious about your answeres... tnx in advance for the time u spend on that, best René |
Re: TL Space True Stereo Routing Issue - HELP
It's been like that since it came out.
If you check, then it "only" uses two DSP's when in medium true stereo, while that is the same in regular stereo. The short true stereo uses 4 DSP's ...as does the long true stereo.
www.olipoulsen.com iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7 Apollo 8 / PT Ultimate 2020.9.1 |
and why digisupport says : ???
Hello Rene I have tested this on Pro Tools HD 7.4 with V8 of TL Space. Again, there seems to be no problem with the routing I have attached a screen shot Have you tried trashing all Digidesign preferences? Response - 01/08/2009 04.04 PM Hi Rene I have tested this with using both a mono and stereo audio track and in both cases I was able to get signal via the right channel on the TL Space plug-in, see attached. Did you install Pro Tools 8 without uninstalling any previously installed version of Pro Tools? If so, you may want to try uninstalling Pro Tools completely from your system and just installing Pro Tools 8 if the problem persists. Digidesign Technical Support |
TL SPACE - what kind of impulses are needed for true stereo?? | BasketCase | Pro Tools TDM Systems (Mac) | 1 | 08-19-2012 02:11 AM |
Routing to give a stereo group a stereo plugin on the VENUE plus AES EBU uses | somtech | VENUE Live Sound Systems | 5 | 05-19-2012 06:43 AM |
Recipe to crash PT 9 = TL Space with True Stereo Impulses | 25ghosts | Pro Tools 9 | 4 | 12-01-2010 03:11 AM |
TL Space - True Stereo | montezuma | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-22-2010 07:39 AM |
PT 8.0.3 & TL Space Latest Version --- True Stereo Madness | 25ghosts | Pro Tools TDM Systems (Mac) | 1 | 02-11-2010 09:07 PM |
