Control24 Phantom Power Supply Pins
Does anyone know which connectors on the power supply feed the Phantom power?
I've lost power to my Phantom and DI's. Thanks! Nic |
Re: Control24 Phantom Power Supply Pins
Did you check the phantom MASTER switch that is hidden on the back of the C24?(and note that it will only work on the MIC inputs, not the line inputs)
I don't know if you solved your phantom problem, but his happened to me just yesterday: there's a little 2-pin connector "thingy" (I'm not a tech) that goes from the PSU to the phantom buttons that managed to disconnect itself when I did the "reseat ritual". When I pulled out the PSU the connector fell inside the Control 24 and I just didn't see it. Maybe that's what happened to yours.
Another time I lost phantom power when the molex connector for one of the banks had an arc and over time one of the wires deteriorated enough that I needed to resolder it. This is easy to access, but you have to take off the bottom skin.
John Tendy Click Recording, Inc. Yorktown Heights, NY |
Would this UPS (Uninterrupted Power Supply) protect and power my gear? | D_Japan | macOS | 4 | 07-24-2011 04:23 PM |
002R Faults + power harness + no phantom power | DaveSB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-26-2009 01:10 AM |
recording with phantom power *and* without phantom power simultaneously | SweetSoulSound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-22-2008 07:40 PM |
Phantom power and mic with power supply? | hotstuff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-20-2005 12:56 PM |
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! | snuffacation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-11-2004 03:03 PM |
