Old 08-26-2003, 06:51 PM
storymaster2k storymaster2k is offline
Default Faders Don\'t Work
All was well yesterday and I did not turn off the C24. This morning the displays on the C24 were showing the volumes jumping up and down from -50db to -47db but the faders weren't moving.
I have read the manuals and the forums and such about calibrating the faders and the proper start up process the board goes through. Nothing is happening. I can adjust anything else and it all corresponds with the Pro Tools Session but the faders do not calibrate and do not move on their own.
Has anyone seen this before. Is there a dead fuse or something else easy to fix or is it a major overhaul? I can hear the faders or rather a fader click once the board boots up but that's about all the life I see out of the faders.
thanks
Old 09-24-2003, 08:36 AM
Offset Offset is offline
Default Re: Faders Don\'t Work
Remove a power supply unit also check up fuses. Fail 2 pieces. I do not remember nominal. A reason Overheating from long operation. Excuse for mine English)
Old 09-25-2003, 07:54 AM
Jan Folkson Jan Folkson is offline
Sounds like the power supply to me. Replacing it is no big deal. I'd call Digi.
HTH.
- Jan Folkson
www.janfolkson.com
Does Aux to Faders Work On Mc Control? Cheesehead Artist Series 1 11-23-2010 06:39 PM
Does anyone know how to unlock faders so they can work individually? Jimibrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-10-2010 08:18 PM
Faders don't work on my digi 002 Bernardes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-21-2006 10:18 AM
My digi 002 faders does'nt work... juguelio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-24-2006 08:11 AM
How Do Motorized Faders Work? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-05-2002 10:20 PM
