Midi Controller not working
I can't get my axiom 25 to control the midi in PT 11 it used to work in 10.3.7 but this is the first time I've hooked it up since upgrading to 11
I hardly ever use it but it would be nice to get it working. any help is greatly appreciated Thanks, Here is computer spec and I included a USB report that shows it as connected SiSoftware Sandra ID Host Name : Timer Workgroup : WORKGROUP Computer Model : HP ENVY m6 Notebook PC 103C_5335KV G=N L=CON B=HP S=PAV Serial Number : CND30***** Chassis : HP Notebook Mainboard : HP 18A4 Serial Number : PDJVNB2******* BIOS : Insyde F.25 01/21/2013 Intel vPro : 8.01.00.1248 Total Memory : 7.9GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz (2C 4T 3.2GHz, 3.2GHz IMC, 2x 256kB L2, 3MB L3) Socket/Slot : FC PGA988 Chipset Memory Controller : HP Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : A-Data AM1U16BC4P2-B19H 4GB DDR3 SO-DIMM PC3-12800S DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module : A-Data AM1U16BC4P2-B19H 4GB DDR3 SO-DIMM PC3-12800S DDR3-1600 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : CMN Generic PnP Monitor (1600x1200, 15.3") Video Adapter : Intel(R) HD Graphics 4000 (16CU 128SP SM5.0 350MHz/1.1GHz, 32MB DDR3 1.6GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.1GHz, 1.8GB DDR3 1.6GHz 128-bit, Integrated Graphics) Compute Shader Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.1GHz, 64MB DDR3 1.6GHz 128-bit, Integrated Graphics) Storage Devices Hitachi HTS547575A9E384 (750.2GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 699GB (C:) (D:) hp CDDVDW SU-208BB (SATA150, DVD+-RW, CD-RW) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 672GB (NTFS) @ Hitachi HTS547575A9E384 (750.2GB, SATA300, 2.5", 5400rpm, 8MB Cache) RECOVERY (D:) : 26GB (NTFS) @ Hitachi HTS547575A9E384 (750.2GB, SATA300, 2.5", 5400rpm, 8MB Cache) WINRE : 400MB (NTFS) Hard Disk : 350MB (NTFS) Optical Drive (E:) : N/A @ hp CDDVDW SU-208BB (SATA150, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : HP Panther Point LPC Controller Audio Device : HP Panther Point High Definition Audio Controller Audio Codec : Integrated Device Tech 76E0 Disk Controller : HP Mobile SATA RAID Controller USB Controller 1 : HP Panther Point USB xHCI Host Controller USB Controller 2 : HP Panther Point USB Enhanced Host Controller #2 USB Controller 3 : HP Panther Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : HP ePrint (600x600, Parallel, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : Ralink RT5390R 802.11bgn Wi-Fi Adapter (802.11n (HT), AES-CCMP, 65Mbps) Power Management Battery No 1 : 13-14 MO06062 58.53Wh/4.64Ah Operating System Windows System : Microsoft Windows 8.1 Home 6.03.9600 Platform Compliance : x64 Windows Experience Index Current System : 5.8 This is the proof that it is hooked to the computer SiSoftware Sandra General Information Controller : USB xHCI Compliant Host Controller Root Hub Compound Device : No Hub Is Bus Powered : No Power Switching : Gang-switched Over-current Protection : Global No. Ports : 8 Root Hub: USB Port 1 Status : Device Connected Manufacturer : iLok Device Connected : iLok Device ID : VEN_088E, DEV_5036, PRT_FF Device Version : 0.20 Serial : A18AA22A_40080E57 USB Version : 2.00 Speed : Full (12Mbps) Configuration Settings : 1 Open Pipes : 2 Transfer Type : Bulk Data Packet Size : 64bytes Root Hub: USB Port 2 Status : Device Connected Manufacturer : M-Audio Device Connected : Axiom 25 Device ID : VEN_0763, DEV_202C, PRT_00 Device Version : 1.26 USB Version : 1.00 Speed : Full (12Mbps) Configuration Settings : 1 Open Pipes : 2 Transfer Type : Bulk Data Packet Size : 64bytes Root Hub: USB Port 3 Status : Device Connected Manufacturer : Focusrite Device Connected : Scarlett 8i6 USB Device ID : VEN_1235, DEV_8002, PRT_01 Device Version : 1.55 Latest Firmware : 2.4A Serial : 00008BC0 USB Version : 2.00 Speed : High (480Mbps) Configuration Settings : 2 Open Pipes : 3 Transfer Type : Interrupt Data Packet Size : 64bytes Root Hub: USB Port 4 Status : Empty Root Hub: USB Port 5 Status : Empty Root Hub: USB Port 6 Status : Empty Root Hub: USB Port 7 Status : Empty Root Hub: USB Port 8 Status : Empty Performance Enhancing Tips Tip 1803 : Disk firmware update available. To update, visit the manufacturer's website. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: Midi Controller not working
Have you gone(in Pro Tools) to Setup>Midi>Midi Studio and created an "instrument"(the Axiom) and selected the input port. This would likely would be something like "Axiom USB(Emulated)" Wish I could be more precise, but i don't have an Axiom, BUT, my midi controllers all work fine, once they are setup as described above
I have not tried that because in previous versions I never had to. do you happen to know what send receive channels should be activated? are they active when they are blue or when they are grey
midi controller not working? | T.Glaze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-06-2015 02:31 PM |
Midi controller not working! | SonnyT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-31-2011 04:10 PM |
midi controller not working with ez drummer | alzuka | MIDI | 3 | 08-18-2009 07:50 PM |
Midi Controller not working | Precava | Pro Tools TDM Systems (Win) | 7 | 12-11-2005 12:01 PM |
USB MIDI CONTROLLER NOT WORKING | NickFLZ | Pro Tools TDM Systems (Mac) | 7 | 07-08-2003 08:48 PM |
