Old 10-17-2007, 12:01 PM
6figgas 6figgas is offline
Default Hear volume without record enabled
Hey, I set this up once, but now trying to set it up in another studio. I'm trying to be able to play the tracks through the 003r and PT without having a track armed. I believe before I did it by selecting or deselecting "audio input", I'm not in front of the system now. Any suggestion?
Thanks in advance
Old 10-17-2007, 12:33 PM
Default Re: Hear volume without record enabled
Alt-K for input only monitoring(maybe Option-K? I'm on a PC)
Old 10-18-2007, 07:42 AM
Thanks albee, I already tried that before I posted and it was a no go. It's PT7.3 running with a 003r and G5. Guess I'll keep searching. Thanks again.
Old 10-18-2007, 11:21 AM
Shawn Simpson Shawn Simpson is offline
On HD systems, you can put a track into "input only" mode without having to have the track armed. It's represented by a small 'i' next to the record arm button. The LE system does not have this feature.
Old 10-18-2007, 11:33 AM
The Dougfather The Dougfather is offline
This is annoyance but i have looked in to this and apparently the only other thing you can do other than record enable a track is setup an aux input which allow audio throughput. I have an 002R and they don't support hardware monitoring hence the no sound, i originally came from an Mbox which has hardware monitoring. GGGGrrrrrrrrrrrhhhhhhhhh
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Can't hear microphone when Low Latency Monitoring is enabled Ferrante Windows 7 12-11-2012 03:50 AM
MIDI record enabled and found but wont record BCRich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-23-2010 12:51 PM
ProTools LE 7.x NAS Share, record enabled Volume nean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-16-2008 03:36 PM
Cant hear record enabled track during playback michaiel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-19-2005 01:59 PM
Let me hear your digi 001,Post your music that you record hear optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-05-2003 12:52 AM
