"Error opening Document" (session file)
Hey guys, I'm new to the DUC, I've had my digi001 for about 6 months now. I was hoping someone could help me with something I haven't seen posted here. I'm running a P4 1.7G, 256M RDram, windows 98se that I built recently. Here's the problem: I created a few sessions in Windows 98 original and then I backed all the data up on cd and just recently upgraded to 98se (i had thought that I had se, but I was wrong) well, when after I set up se and installed pro tools and tested that the demo session that came with the cd worked (it worked perfectly) I tried opening one of my previously saved sessions and immediately I got the message "error with open session command, could not open document" or something very close to that. Also if it helps one of the sessions was a template and was saved and burned as "read-only", the other was just archive, but when I transferred from the cdr to the hard drive, under properties they were read only and archive, I've tried changing these but to no avail. I would greatly appreciate any help, I know you guys are the best! Thanks!
[email protected] |
Re: "Error opening Document" (session file)
you have to select everything in the folder you put back to your harddisk from cd and uncheck the read-only checkbox. Except the template you made ofcourse.
What's that? - That's the machine that goes "pling". Bastiaan |
Thanks a lot for the quick reply, I will try that when I get home and hopefully that will work, I'll let you know tomorrow, Thanks!
[email protected] |
I was really hoping that would work, but unfortunately I got the same message. The exact wording is:
Could not complete the "Open Session..." command because: an error occurs while reading the document. Any other ideas? I wonder if it has anything to do with upgrading to 98SE, from 98, I wouldn't think so, but maybe. Thanks!
[email protected] |
If you are running PT LE 5.1 or later, create a New Session and use the File>Import Tracks command to move the data into the new session file...will it open?
Brent |
I'm at work, so I'll try when I get home to import the wav files to a new session. I'll respond tomorrow morning and hopefully we can figure something out from there, thanks a million!
[email protected] |
Yeah, I can 'import audio to track', but I cannot 'import track'. I think I am going to run screaming back to Windows 98 original, I'm having nothing but errors with SE, none of my bombfactory or waves plugs work either, I get some sort of DAE error.
[email protected] |
strange.....i hahe '98se and everything works fine....waves and d-verb also (the only other plugins i have)
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." | Elias Stiza | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2012 07:06 PM |
Bus error in thread "mainthread", at address 0x0 - when opening a session | skote | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-08-2011 08:11 AM |
"unable to parse audio file" and "OSStatus Error -208" ! | reichman | Post - Surround - Video | 2 | 03-22-2010 04:46 AM |
Error: "pro tools session version too new while translating document" | stonerebel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-30-2008 10:25 AM |
Help!! When opening session, window pops up saying "file not on a valid drive?" ?? | Rockman-Songwriter | Pro Tools TDM Systems (Mac) | 9 | 04-25-2003 04:03 PM |
