help!! quick routing/bussing fix needed
I've got about 40 tracks of backgrounds and need to bouce them to a stereo pair. I know that I could bounce to disk (which I 'd rather not do) or bus them to a stereo track. The only thing is that i get tired of have to change each output on each track in order to bus them. Is there a way to just change the outputs on those 40 tracks all at once without using the option key which would change the all of the outputs for the entire song?
thanks in advance ej |
Re: help!! quick routing/bussing fix needed
Shift-click the name of each vocal track so only the vocal tracks are hightlighted. Then Shift-Option one of the tracks and click the outputs you want. Shift-Option only affects the highlighted tracks.
HD3 accel PT 6.9.2 OSX 10.4.1 G5 dual 2.0 3gig ram |
thank you!!!!!!
you've just saved me a lot of time ej |
Bussing and Routing Advice please | lightning ad | Post - Surround - Video | 8 | 04-26-2012 01:07 AM |
I need a quick reminder.(Bussing tracks to Aux for quick fade out) | mexablcknesekid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-16-2010 09:28 PM |
Bussing - Routing - Assigning - IDEAS? | jayprotools | Pro Tools TDM Systems (Mac) | 9 | 07-27-2009 09:34 AM |
routing/bussing books? | lightning ad | Post - Surround - Video | 4 | 08-05-2005 04:25 AM |
bussing configuration routing | walters | Tips & Tricks | 6 | 05-28-2005 06:12 AM |
