Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 01-03-2009, 03:54 AM
newtonab newtonab is offline
Default "But I could play sound just ten minutes ago."
I was recording earlier and had enough space to playback the audio.
Now every time I hit play I get an error message that reads:
"DAE can't get audio from the drive(s) fast enough. Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwith or CPU load."
I don't use a firewire though.
I've just used so much space that I can't even effectively use the disk defragmenter.
My next purchase is going to be an external hard drive to clear some space and defrag the computer.
3 questions:
1. Is there anyway I could clear space up again or fix the problem of not being able to play anything I've recorded?
2. is it a good idea to save sessions to an external hard drive? Are there any recommendations for what type of external hard drive I should use?
3. I have an IDE/ATA internal drive. Should I use this or record through an eternal hard drive?
Thanks
Old 01-03-2009, 11:24 AM
Craig F Craig F is offline
Default Re: "But I could play sound just ten minutes ago."
more system specs please
tower or laptop
G3, G4, G5, Intel
Le or HD
the little things
Thank you,
Craig
Old 01-03-2009, 05:33 PM
Laptop
XP Home Edition
M-Powered
anything else?
Old 01-10-2009, 03:36 PM
fredson fredson is offline
im having the same problem too and just looking to buy an external hard drive , but what i did when recording was 1) try increasing your cpu usage limit at play back engine
2) go to preferences> operation > and set the time of recording to like 20 or 30
3) uncheck the save backup at the preferences but this a bit risky but try to save your work , what i notice was that PT keep saving a back up copy at a spec time so i guess this might be putting more presure on the hard drives and i try not to save very often
when i did this it tends to not poping the error like b4 but to get an external hard drive is the best
Old 01-10-2009, 09:06 PM
myke2242's Avatar
myke2242 myke2242 is offline
Can you playback other sessions on this same drive?
Old 01-11-2009, 03:33 PM
yeah but sessions with more tracks tends to give this errors often
CANNOT PLAY SOUND THROUGH MY SPEAKERS no itunes or web. They play "internal" jamez Pro Tools 9 1 11-19-2012 12:22 PM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 06:45 AM
How do you get a "Haunted" or "ghostly" sound yijvapar Virtual Instruments 9 08-03-2009 07:04 PM
"cpu" errors after 15-20 minutes of no problems JamLewis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 03-09-2009 06:13 AM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
