Old 06-08-2007, 07:00 AM
Default PT doesn´t play back pan-automation
I´ve found that 7.3.1cs3 (and cs2) tend to stop reproducing pan-automation I write to tracks. I can hear the pan fine while writing a pass. Then all is fine when playing back but after playing over the section a few times, doing some edits here and there the pan just sticks at one speaker. A restart fixes it but it´s mostly random.
Bouncing is just roulette. Sometimes I have to recrecord 2-3 times, restart etc. till PT plays the automation like it´s supposed to.
Currently I found this when bussing mono-tracks to an LCR bus returned to an LCR-aux that goes to the interface.
When I open the channel-strip the pan-pots are not moving although the automation is there, neither suspended now decativated. There are no further plugs on these tracks.
Pretty scare when you do virtual mixes and do a layback and all sounds different every time you play over a section. Sometimes the pan stick left, sometimes in the center sometimes right then it will work fine again aver a couple of minutes.
Scary...
Frank.
7.3.1cs3 10.4.8 2x2.5GHz G5, HD2
Old 06-08-2007, 09:05 AM
mr.armadillo mr.armadillo is offline
Default Re: PT doesn´t play back pan-automation
See this thread .
Old 06-08-2007, 09:22 AM
Thanks,
sounds like it´s that exact bug.
I´ve also found that it seems to happen when working in touch mode. If you switch back to "read" the problem seems to go away.
Of course this isn´t a great way to write automation while in "read" mode.
Frank.
Old 06-09-2007, 12:57 AM
Pietari Koskinen Pietari Koskinen is offline
See also this thread. Hitting suspend automation button twice is one workaround that may help.
Old 06-09-2007, 05:38 AM
Thanks, I´ll try that.
frank.
Old 06-09-2007, 11:18 AM
Pythagor Pythagor is offline
We experience the same and i connect it with memory leak. Adding more memory delays but not eliminate the problem.
too bad
HTML code is On
iTunes doesn´t play the wav-files converted in PT 5.1.1 Viper Pro Tools TDM Systems (Mac) 3 04-28-2012 02:42 PM
BUG: automation doesn´t follow Frank Kruse Post - Surround - Video 79 01-07-2012 11:59 AM
automation doesn´t follow time-stretching tonwurm Pro Tools TDM Systems (Mac) 3 03-09-2010 01:28 AM
Automation refusing to play back 3over3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-13-2007 02:35 AM
Focusrite automation doesn´t work Benyvin Pro Tools TDM Systems (Mac) 0 04-22-2003 12:38 AM
